Giriş
In this guide, you will be separating the motherboard from the Midframe of the GoPro Hero5 Black. The GoPro Hero5 Black is waterproofed with plenty of adhesives. By completing this guide, you will have to remove the adhesive and your GoPro will no longer be waterproof.
Neye ihtiyacın var
While pressing the button on the bottom of the GoPro, slide the battery door to the side to pop it open.
Refer to the iOpener instructions for how to heat up and use the iOpener.
Apply the heated iOpener to the front of the GoPro for a few minutes to melt the adhesive under the faceplate.
Use the flat end of the spudger to pry the black cover plate straight up from its socket on the motherboard.
20 farklı kişi bu kılavuzu tamamladı.
11Kılavuz Yorumları
I used this guide to replace the USB port in my GP5. Does anyone know of a good way to hold the face plate down once it’s been removed? Not looking to make it waterproof again, just trying to hold the faceplate down a little better.
I would try either a silicone- or cyanoacrylate- (super glue) based adhesive. You can try to peel off the blue gasket and/or sand where the two pieces meet for better adhesion.
