Ana içeriğe geç
GoPro Karma Arms Replacement
Neye ihtiyacın var
  1. GoPro Karma Arms Replacement, Battery: adım 1, 1 resimden 1.
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Arms Replacement, Stabilizer: adım 2, 3 resimden 1. GoPro Karma Arms Replacement, Stabilizer: adım 2, 3 resimden 2. GoPro Karma Arms Replacement, Stabilizer: adım 2, 3 resimden 3.
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Arms Replacement: adım 3, 1 resimden 1.
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Arms Replacement, Landing Gear: adım 4, 1 resimden 1.
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Arms Replacement: adım 5, 1 resimden 1.
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Arms Replacement: adım 6, 2 resimden 1. GoPro Karma Arms Replacement: adım 6, 2 resimden 2.
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
  7. GoPro Karma Arms Replacement, Arms: adım 7, 1 resimden 1.
    • Remove the two 1.2 cm long hex screws with a Hex 2.0 screwdriver and set them aside.
  8. GoPro Karma Arms Replacement: adım 8, 2 resimden 1. GoPro Karma Arms Replacement: adım 8, 2 resimden 2.
    • Remove both locked connectors by pushing the connector release tool into the hole in the center and pulling up with the white handles.
    • The connector release tool is only included with the purchase of a replacement arm from the GoPro website.
    • If you do not have a connector release tool, use a small screwdriver to push each tab while pulling up with the white handles.
  9. GoPro Karma Arms Replacement: adım 9, 3 resimden 1. GoPro Karma Arms Replacement: adım 9, 3 resimden 2. GoPro Karma Arms Replacement: adım 9, 3 resimden 3.
    • Remove the cover plate by pulling up on the side.
    • Feed each connector through the hole and set aside the cover plate.
  10. GoPro Karma Arms Replacement: adım 10, 2 resimden 1. GoPro Karma Arms Replacement: adım 10, 2 resimden 2.
    • Loosen the 2 cm long hex screw in the arm with a Hex 2.0 screwdriver.
    • The screw will not come out but loosen it until it can rotate easily.
    • Pull up and off the broken arm.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kyle Hoff
141 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G14
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 2,234
