Ana içeriğe geç
GoPro Karma Harness Replacement
Neye ihtiyacın var
  1. GoPro Karma Harness Replacement, Stabilizer: adım 1, 3 resimden 1. GoPro Karma Harness Replacement, Stabilizer: adım 1, 3 resimden 2. GoPro Karma Harness Replacement, Stabilizer: adım 1, 3 resimden 3.
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Harness Replacement: adım 2, 1 resimden 1.
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  3. GoPro Karma Harness Replacement, Harness: adım 3, 3 resimden 1. GoPro Karma Harness Replacement, Harness: adım 3, 3 resimden 2. GoPro Karma Harness Replacement, Harness: adım 3, 3 resimden 3.
    • Place finger on the tab to open the harness and remove the camera.
    • Be sure to pull the camera straight out lest you damage the connectors.
  4. GoPro Karma Harness Replacement: adım 4, 1 resimden 1.
    • Using a Hex 2.0mm screwdriver, remove the two 12 mm hex screws closest to the harness.
  5. GoPro Karma Harness Replacement: adım 5, 3 resimden 1. GoPro Karma Harness Replacement: adım 5, 3 resimden 2. GoPro Karma Harness Replacement: adım 5, 3 resimden 3.
    • Pull the harness off of the stabilizer.
    • Be sure to pull the harness straight off lest you damage the connector.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Max Verspieren
97 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G14
4 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,366
