Ana içeriğe geç
GoPro Karma Landing Gear Replacement
Neye ihtiyacın var
  1. GoPro Karma Landing Gear Replacement, Battery: adım 1, 1 resimden 1.
    • Hook your fingers on the tab and pull out the battery.
  2. GoPro Karma Landing Gear Replacement, Stabilizer: adım 2, 3 resimden 1. GoPro Karma Landing Gear Replacement, Stabilizer: adım 2, 3 resimden 2. GoPro Karma Landing Gear Replacement, Stabilizer: adım 2, 3 resimden 3.
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  3. GoPro Karma Landing Gear Replacement: adım 3, 1 resimden 1.
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  4. GoPro Karma Landing Gear Replacement, Landing Gear: adım 4, 1 resimden 1.
    • Flip the drone upside down with the landing gear out.
    • Remove the four 1.2 cm long hex screws with a Hex 2.0 screwdriver in the four corners of the landing gear
  5. GoPro Karma Landing Gear Replacement: adım 5, 1 resimden 1.
    • Push with your thumb and pull up with your fingers to remove the landing gear.
    • Caution: The landing gear is connected by a thin cable so do not pull too far away.
  6. GoPro Karma Landing Gear Replacement: adım 6, 2 resimden 1. GoPro Karma Landing Gear Replacement: adım 6, 2 resimden 2.
    • Flip over the landing gear and locate the cable connector.
    • Use your thumbnail to disconnect the cable and free the landing gear.
Sonuç
Jay Ingram
334 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G14
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 17
Her zaman: 616
