Ana içeriğe geç
GoPro Karma Propeller Replacement
    1. GoPro Karma Propeller Replacement, Battery: adım 1, 1 resimden 1.
      • Hook your fingers on the tab and pull out the battery.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Karma Propeller Replacement, Stabilizer: adım 2, 3 resimden 1. GoPro Karma Propeller Replacement, Stabilizer: adım 2, 3 resimden 2. GoPro Karma Propeller Replacement, Stabilizer: adım 2, 3 resimden 3.
      • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
      • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Karma Propeller Replacement: adım 3, 1 resimden 1.
      • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
      FixBot'a Sor
      Yorum Ekle
    1. GoPro Karma Propeller Replacement, Propeller: adım 4, 3 resimden 1. GoPro Karma Propeller Replacement, Propeller: adım 4, 3 resimden 2. GoPro Karma Propeller Replacement, Propeller: adım 4, 3 resimden 3.
      • Extend the arms and set the drone face up.
      • The front right and back left propellers unscrew clockwise.
      • The front left and back right propellers unscrew counterclockwise.
      FixBot'a Sor
      Yorum Ekle
    2. GoPro Karma Propeller Replacement: adım 5, 2 resimden 1. GoPro Karma Propeller Replacement: adım 5, 2 resimden 2.
      • Place the GoPro Karma wrench on the motor.
      • Hold the motor in place with the wrench and unscrew the propeller in the indicated direction.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Jay Ingram
334 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G14, Maness Spring 2018 Cal Poly, Team S25-G14, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G14
4 Üyeler
60 adet Kılavuz yazıldı
2Kılavuz Yorumları
You got it the wrong way around, to take them off you need to do the exact opposite to what you say.
michael.woelk - Yanıt Paylaş
hi, i am trying to fix my Karma. I have to remove the propellers but it is like they are stocked.
I try to unscrew the propellers but i can’t remove them.
Do you know what to do in this case?
Davide Negro - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 36
Her zaman: 2,187
