Ana içeriğe geç
Golf Club Grip Replacement
Neye ihtiyacın var
  1. Golf Club Grip Replacement, Grip: adım 1, 2 resimden 1. Golf Club Grip Replacement, Grip: adım 1, 2 resimden 2.
    • Place the golf club securely on a level table.
    • Using a blade or knife, cut a line through the grip.
  2. Golf Club Grip Replacement: adım 2, 3 resimden 1. Golf Club Grip Replacement: adım 2, 3 resimden 2. Golf Club Grip Replacement: adım 2, 3 resimden 3.
    • Remove the grip from the golf club shaft.
  3. Golf Club Grip Replacement: adım 3, 1 resimden 1.
    • Use the knife to take off any excess residue from the shaft of the club.
  4. Golf Club Grip Replacement: adım 4, 2 resimden 1. Golf Club Grip Replacement: adım 4, 2 resimden 2.
    • Apply the double sided tape to the bare shaft in a spiral pattern.
    • Use the grip to determine how far up the shaft the tape needs to go.
  5. Golf Club Grip Replacement: adım 5, 1 resimden 1.
    • Remove the tape backing.
  6. Golf Club Grip Replacement: adım 6, 3 resimden 1. Golf Club Grip Replacement: adım 6, 3 resimden 2. Golf Club Grip Replacement: adım 6, 3 resimden 3.
    • Place a golf tee in the hole at the end of the golf grip.
  7. Golf Club Grip Replacement: adım 7, 2 resimden 1. Golf Club Grip Replacement: adım 7, 2 resimden 2.
    • Pour a generous amount of adhesive into the opposite end of the grip.
    • Squeeze together the open end of the grip.
    • Lightly shake, in order to spread the adhesive within the grip.
  8. Golf Club Grip Replacement: adım 8, 1 resimden 1.
    • Over a bowl or container, pour adhesive in the grip onto the shaft of the golf club.
  9. Golf Club Grip Replacement: adım 9, 2 resimden 1. Golf Club Grip Replacement: adım 9, 2 resimden 2.
    • Remove the tee from the back of the grip.
    • Push the grip onto the golf club shaft.
    • Ensure that the end of the grip is hitting the end of the shaft.
  10. Golf Club Grip Replacement: adım 10, 1 resimden 1.
    • Allow to dry at least 12 hours before use.
Sonuç
After allowing the club to properly dry, you will have a new grip to improve your swing at tee off.
6 farklı kişi bu kılavuzu tamamladı.
Skylar Nichols
212 İtibar
1 Kılavuz yazıldı
Ekip
Missouri Western, Team 1-8, Adkins Fall 2016 Missouri Western, Team 1-8, Adkins Fall 2016 üyesi
MWSU-ADKINS-F16S1G8
3 Üyeler
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 22
Her zaman: 7,382
