Ana içeriğe geç
Golf Club Shaft Replacement
Neye ihtiyacın var
  1. Golf Club Shaft Replacement, Shaft: adım 1, 1 resimden 1.
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: adım 2, 3 resimden 1. Golf Club Shaft Replacement: adım 2, 3 resimden 2. Golf Club Shaft Replacement: adım 2, 3 resimden 3.
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: adım 3, 2 resimden 1. Golf Club Shaft Replacement: adım 3, 2 resimden 2.
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: adım 4, 1 resimden 1.
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: adım 5, 3 resimden 1. Golf Club Shaft Replacement: adım 5, 3 resimden 2. Golf Club Shaft Replacement: adım 5, 3 resimden 3.
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: adım 6, 3 resimden 1. Golf Club Shaft Replacement: adım 6, 3 resimden 2. Golf Club Shaft Replacement: adım 6, 3 resimden 3.
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: adım 7, 3 resimden 1. Golf Club Shaft Replacement: adım 7, 3 resimden 2. Golf Club Shaft Replacement: adım 7, 3 resimden 3.
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
George Bassili
166 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 10
Her zaman: 1,536
