Ana içeriğe geç
Google Chromebook Pixel 2 Back Panel Replacement
Neye ihtiyacın var
  1. Google Chromebook Pixel 2 Back Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Back Panel Replacement: adım 2, 1 resimden 1.
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Back Panel Replacement: adım 3, 2 resimden 1. Google Chromebook Pixel 2 Back Panel Replacement: adım 3, 2 resimden 2.
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Back Panel Replacement: adım 4, 1 resimden 1.
    • Carefully lift the back panel off of the device.
Sonuç
Garrett Monteiro
413 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G6, Livingston Spring 2017 Cal Poly, Team S22-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G6
4 Üyeler
Bir Yorum
Where can I buy replacements for the rubber strips? They never quite fit again and eventually were coming off and sticking to things, so had to throw them away.
Marc Bernard Schauber - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,402
