Ana içeriğe geç
Google Chromebook Pixel 2 Fan Replacement
Neye ihtiyacın var
  1. Google Chromebook Pixel 2 Fan Replacement, Back Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Fan Replacement: adım 2, 1 resimden 1.
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Fan Replacement: adım 3, 2 resimden 1. Google Chromebook Pixel 2 Fan Replacement: adım 3, 2 resimden 2.
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Fan Replacement: adım 4, 1 resimden 1.
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Fan Replacement, Fan: adım 5, 2 resimden 1. Google Chromebook Pixel 2 Fan Replacement, Fan: adım 5, 2 resimden 2.
    • Remove the three blue 4.0 mm Phillips #00 screws from the fan on the right side.
  6. Google Chromebook Pixel 2 Fan Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool, slide out the right fan’s connector out of the motherboard slot.
  7. Google Chromebook Pixel 2 Fan Replacement: adım 7, 1 resimden 1.
    • Carefully remove lift the right fan out of its slot.
  8. Google Chromebook Pixel 2 Fan Replacement: adım 8, 2 resimden 1. Google Chromebook Pixel 2 Fan Replacement: adım 8, 2 resimden 2.
    • Remove three blue 4.0 mm Phillips #00 screws from the left fan.
  9. Google Chromebook Pixel 2 Fan Replacement: adım 9, 1 resimden 1.
    • Using the plastic opening tool, slide out the left fan’s connector.
  10. Google Chromebook Pixel 2 Fan Replacement: adım 10, 1 resimden 1.
    • Gently lift the left fan out of its slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Garrett Monteiro
413 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G6, Livingston Spring 2017 Cal Poly, Team S22-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 142
