Ana içeriğe geç
Google Chromebook Pixel 2 Speaker Replacement
Neye ihtiyacın var
  1. Google Chromebook Pixel 2 Speaker Replacement, Back Panel: adım 1, 1 resimden 1.
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Flip your device over so the bottom panel is facing up.
  2. Google Chromebook Pixel 2 Speaker Replacement: adım 2, 1 resimden 1.
    • Peel off the black rubber strips from top and bottom of the back panel.
  3. Google Chromebook Pixel 2 Speaker Replacement: adım 3, 2 resimden 1. Google Chromebook Pixel 2 Speaker Replacement: adım 3, 2 resimden 2.
    • Remove the fifteen 3 mm Phillips #00 screws from the back panel.
  4. Google Chromebook Pixel 2 Speaker Replacement: adım 4, 1 resimden 1.
    • Carefully lift the back panel off of the device.
  5. Google Chromebook Pixel 2 Speaker Replacement, Speaker: adım 5, 1 resimden 1.
    • Remove the three red 4.5 mm Phillips #00 screws from the speaker on the right sight of the motherboard.
  6. Google Chromebook Pixel 2 Speaker Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool disconnect the speaker wires from the motherboard,
  7. Google Chromebook Pixel 2 Speaker Replacement: adım 7, 1 resimden 1.
    • Carefully remove right speaker from the device.
  8. Google Chromebook Pixel 2 Speaker Replacement: adım 8, 1 resimden 1.
    • Using the plastic opening tool, pop out the connector that joins the headphone jack port on the left side to the motherboard.
  9. Google Chromebook Pixel 2 Speaker Replacement: adım 9, 1 resimden 1.
    • Remove the red 4.5 mm Phillips #00 screw from the top of the headphone jack port.
  10. Google Chromebook Pixel 2 Speaker Replacement: adım 10, 1 resimden 1.
    • Gently remove the headphone jack port.
  11. Google Chromebook Pixel 2 Speaker Replacement: adım 11, 2 resimden 1. Google Chromebook Pixel 2 Speaker Replacement: adım 11, 2 resimden 2.
    • Remove the three red 4.5 mm Phillips #00 screws from the speaker.
  12. Google Chromebook Pixel 2 Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the left speaker.
Sonuç
Garrett Monteiro
413 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S22-G6, Livingston Spring 2017 Cal Poly, Team S22-G6, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S22G6
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 73
