Ana içeriğe geç
Google Cr-48 Chromebook Bottom Casing Replacement
Neye ihtiyacın var
  1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: adım 1, 3 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: adım 1, 3 resimden 2. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: adım 1, 3 resimden 3.
    • To take out the battery, slide the switch on the bottom of the laptop.
    • The battery should then pop out and you can remove it.
    FixBot'a Sor
    Yorum Ekle
  2. Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: adım 2, 2 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement, Bottom Casing: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, remove the two rear rubber feet. You should then see the two screws underneath.
    FixBot'a Sor
    Yorum Ekle
  3. Google Cr-48 Chromebook Bottom Casing Replacement: adım 3, 3 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement: adım 3, 3 resimden 2. Google Cr-48 Chromebook Bottom Casing Replacement: adım 3, 3 resimden 3.
    • First, position the computer to have the silver battery compartment closest to you. Then, using a Phillips #00 screwdriver, remove the ten 3 mm screws in the battery compartment.
    • Now, using the same screwdriver, remove the two 4.5 mm screws that were underneath the previously removed rubber feet.
    FixBot'a Sor
    Yorum Ekle
  4. Google Cr-48 Chromebook Bottom Casing Replacement: adım 4, 3 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement: adım 4, 3 resimden 2. Google Cr-48 Chromebook Bottom Casing Replacement: adım 4, 3 resimden 3.
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robert McLaughlin
471 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 31
Her zaman: 1,174
