Ana içeriğe geç
Google Cr-48 Chromebook Bottom Casing Replacement
Neye ihtiyacın var
  1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: adım 1, 3 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: adım 1, 3 resimden 2. Google Cr-48 Chromebook Bottom Casing Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Google Cr-48 Chromebook Bottom Casing Replacement, Remove Rear Rubber Feet: adım 2, 2 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement, Remove Rear Rubber Feet: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Google Cr-48 Chromebook Bottom Casing Replacement, Remove Screws: adım 3, 3 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement, Remove Screws: adım 3, 3 resimden 2. Google Cr-48 Chromebook Bottom Casing Replacement, Remove Screws: adım 3, 3 resimden 3.
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Google Cr-48 Chromebook Bottom Casing Replacement: adım 4, 3 resimden 1. Google Cr-48 Chromebook Bottom Casing Replacement: adım 4, 3 resimden 2. Google Cr-48 Chromebook Bottom Casing Replacement: adım 4, 3 resimden 3.
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Robert McLaughlin
462 İtibar
3 adet Kılavuz yazıldı
Ekip
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 10
Her zaman: 852
