Ana içeriğe geç
Giriş
If you want your device to be able to handle multiple tasks smoothly, have faster memory, and boost the efficiency of your workflow, you may want to replace or upgrade your RAM. The following guide shows you how to replace the RAM in your Google Cr-48 Chromebook in seven easy steps.
Your computer's RAM or random access memory gives applications a place to store and access short-term data. RAM is one of your computer's most important components for improving performance. If you notice your system is sluggish, or you have frequent crashes, reboots, blue screens, distorted graphics, or memory errors, it may be due to having too little RAM. Replacing the RAM in your Google Cr-48 Chromebook requires no specific skills and no advanced tools besides a Phillips screwdriver, any pair of household tweezers, and of course your new RAM.
Parçalar
Hiçbir parça belirtilmedi.
  1. Google Cr-48 Chromebook RAM Replacement, Battery: adım 1, 3 resimden 1. Google Cr-48 Chromebook RAM Replacement, Battery: adım 1, 3 resimden 2. Google Cr-48 Chromebook RAM Replacement, Battery: adım 1, 3 resimden 3.
    • Slide the switch on the bottom of the laptop until the battery pops out.
    • Once the battery pops out, you can remove it.
  2. Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: adım 2, 2 resimden 1. Google Cr-48 Chromebook RAM Replacement, Remove Rear Rubber Feet: adım 2, 2 resimden 2.
    • Using a pair of tweezers, remove the two rear rubber feet to expose two hidden screws.
  3. Google Cr-48 Chromebook RAM Replacement, Remove Screws: adım 3, 3 resimden 1. Google Cr-48 Chromebook RAM Replacement, Remove Screws: adım 3, 3 resimden 2. Google Cr-48 Chromebook RAM Replacement, Remove Screws: adım 3, 3 resimden 3.
    • Remove ten 3 mm screws in the battery compartment using a Phillips #00 screwdriver.
    • Remove two 4.5 mm screws under the rubber feet using a Phillips #00 screwdriver.
  4. Google Cr-48 Chromebook RAM Replacement: adım 4, 3 resimden 1. Google Cr-48 Chromebook RAM Replacement: adım 4, 3 resimden 2. Google Cr-48 Chromebook RAM Replacement: adım 4, 3 resimden 3.
    • Starting where the body of the laptop and the laptop screen meet, pry apart the lower case from the rest of the laptop.
    • The case is easier to remove when separating in a clockwise motion, as seen in the pictures.
  5. Google Cr-48 Chromebook RAM Replacement, RAM: adım 5, 3 resimden 1. Google Cr-48 Chromebook RAM Replacement, RAM: adım 5, 3 resimden 2. Google Cr-48 Chromebook RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Locate the RAM under a black flap alongside where the laptop screen and device body meet.
  6. Google Cr-48 Chromebook RAM Replacement: adım 6, 3 resimden 1. Google Cr-48 Chromebook RAM Replacement: adım 6, 3 resimden 2. Google Cr-48 Chromebook RAM Replacement: adım 6, 3 resimden 3.
    • Locate the metal clasps on either side of the RAM Card. Using your thumbs, pull the pieces away from the RAM and then the RAM card should pop up.
  7. Google Cr-48 Chromebook RAM Replacement: adım 7, 2 resimden 1. Google Cr-48 Chromebook RAM Replacement: adım 7, 2 resimden 2.
    • Use two fingers to pull the RAM upwards and out.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Athar
365 İtibar
2 adet Kılavuz yazıldı
CSU Fullerton, Team 2-2, Bruce Fall 2014 CSU Fullerton, Team 2-2, Bruce Fall 2014 üyesi
CSUF-BRUCE-F14S2G2
3 Üyeler
10 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 1,488
