Ana içeriğe geç
Google Home Interconnect Cable Replacement
Neye ihtiyacın var
  1. Google Home Interconnect Cable Replacement, Interconnect Cable: adım 1, 3 resimden 1. Google Home Interconnect Cable Replacement, Interconnect Cable: adım 1, 3 resimden 2. Google Home Interconnect Cable Replacement, Interconnect Cable: adım 1, 3 resimden 3.
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Interconnect Cable Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove the interconnect cable using a pair of tweezers.
Sonuç
Gabe Hyun
835 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G11
4 Üyeler
5 adet Kılavuz yazıldı
1Rehber Yorum
What cord can you replace with? There is an adaptor attached.
Katti Sundelin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 8
Her zaman: 751
