Ana içeriğe geç
Google Home Mini USB Power Port Replacement
Neye ihtiyacın var
  1. Google Home Mini USB Power Port Replacement, Google Home Mini Disassembly: adım 1, 1 resimden 1.
    • Place device on a flat surface.
  2. Google Home Mini USB Power Port Replacement: adım 2, 1 resimden 1.
  3. Google Home Mini USB Power Port Replacement: adım 3, 1 resimden 1.
    • Remove the lower half of the device.
    • Be careful as a black ribbon cable connects the two halves together.
  4. Google Home Mini USB Power Port Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using a pair of tweezers, unlatch the Zero Insertion Force (ZIF) fastener that connects the ribbon cable to the board.
    • Flip up and push the ZIF fastener towards outside of the lower case to loosen it.
  5. Google Home Mini USB Power Port Replacement: adım 5, 1 resimden 1.
    • Pull the ribbon cable off.
  6. Google Home Mini USB Power Port Replacement, USB Power Port: adım 6, 2 resimden 1. Google Home Mini USB Power Port Replacement, USB Power Port: adım 6, 2 resimden 2.
    • Remove the three 5.3mm T6 Torx screws from the board.
  7. Google Home Mini USB Power Port Replacement: adım 7, 2 resimden 1. Google Home Mini USB Power Port Replacement: adım 7, 2 resimden 2.
    • Remove the black metal plate from the board.
  8. Google Home Mini USB Power Port Replacement: adım 8, 2 resimden 1. Google Home Mini USB Power Port Replacement: adım 8, 2 resimden 2.
    • Remove the board.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Mia Sulaiman
1.080 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G4, Harley Spring 2018 IUPUI, Team S1-G4, Harley Spring 2018 üyesi
IUPUI-HARLEY-S18S1G4
7 Üyeler
5 adet Kılavuz yazıldı
9Kılavuz Yorumları
Where I can buy micro USB PCB ?
so_ang - Yanıt
Planet Carl - Yanıt
Would like to know this as well disapointing to have an instruction on how to replace a part, but nowere to buy it.
Wolve 8383 - Yanıt
Has anyone had any luck buying a replacement part?
Caitlin Barnum - Yanıt
Just broke mine :-(
Is anyone managed to find a place to buy one?
Jim - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 52
Her zaman: 6,795
