Ana içeriğe geç
Google Home Mute Button Switch Replacement
Neye ihtiyacın var
  1. Google Home Mute Button Switch Replacement, Interconnect Cable: adım 1, 3 resimden 1. Google Home Mute Button Switch Replacement, Interconnect Cable: adım 1, 3 resimden 2. Google Home Mute Button Switch Replacement, Interconnect Cable: adım 1, 3 resimden 3.
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Mute Button Switch Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Mute Button Switch Replacement, Mute Button Switch: adım 3, 2 resimden 1. Google Home Mute Button Switch Replacement, Mute Button Switch: adım 3, 2 resimden 2.
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Mute Button Switch Replacement: adım 4, 2 resimden 1. Google Home Mute Button Switch Replacement: adım 4, 2 resimden 2.
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Gabe Hyun
835 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G11
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 957
