Ana içeriğe geç
Google Home Sound Driver Replacement
Neye ihtiyacın var
  1. Google Home Sound Driver Replacement, Interconnect Cable: adım 1, 3 resimden 1. Google Home Sound Driver Replacement, Interconnect Cable: adım 1, 3 resimden 2. Google Home Sound Driver Replacement, Interconnect Cable: adım 1, 3 resimden 3.
    • Removing the lid too quickly could cause you to tear the interconnect cable that attaches the base to the top of the lid.
    • Pull off the Google Home’s magnetically attached base and set it aside.
    • Using a Torx T6 screwdriver head, unscrew the four 1.7mm Torx screws deep in the speaker recess so that you can remove the lid.
    • After all four screws are out, pop the lid off the device to open the capsule.
  2. Google Home Sound Driver Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove the interconnect cable using a pair of tweezers.
  3. Google Home Sound Driver Replacement, Mute Button Switch: adım 3, 2 resimden 1. Google Home Sound Driver Replacement, Mute Button Switch: adım 3, 2 resimden 2.
    • Remove the ‘O-ring’ that wraps around the device holding the switch panel in place.
  4. Google Home Sound Driver Replacement: adım 4, 2 resimden 1. Google Home Sound Driver Replacement: adım 4, 2 resimden 2.
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws.
    • Remove the panel and the mute button switch. If done correctly you should now be able to see the device’s guitar-shaped motherboard.
  5. Google Home Sound Driver Replacement, Motherboard: adım 5, 2 resimden 1. Google Home Sound Driver Replacement, Motherboard: adım 5, 2 resimden 2.
    • Disconnect the foam-padded, red and black cable that connects the motherboard to the sound driver, by squeezing and pulling on the tab
    • Disconnect the orange interconnect cable that connects the bottom of the device to the motherboard by pulling straight out on the orange tab.
  6. Google Home Sound Driver Replacement: adım 6, 2 resimden 1. Google Home Sound Driver Replacement: adım 6, 2 resimden 2.
    • Using a Torx T6 screwdriver head, unscrew the five silver 1.7mm Torx screws keeping the motherboard in place.
    • Remove the motherboard.
  7. Google Home Sound Driver Replacement, Sound Driver: adım 7, 2 resimden 1. Google Home Sound Driver Replacement, Sound Driver: adım 7, 2 resimden 2.
    • Using a Torx T6 screwdriver head, unscrew the four black 1.7mm Torx screws on the bottom of the device.
    • For this step you will need a T6 screwdriver with an extra long head to reach the screws.
  8. Google Home Sound Driver Replacement: adım 8, 2 resimden 1. Google Home Sound Driver Replacement: adım 8, 2 resimden 2.
    • Using a Torx T6 screwdriver head, unscrew the six black 1.7mm Torx screws on the side of the device.
  9. Google Home Sound Driver Replacement: adım 9, 2 resimden 1. Google Home Sound Driver Replacement: adım 9, 2 resimden 2.
    • Pull apart the black casing to reveal the sound driver.
    • Remove the sound driver.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Gabe Hyun
835 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S24-G11, Maness Spring 2018 Cal Poly, Team S24-G11, Maness Spring 2018 üyesi
CPSU-MANESS-S18S24G11
4 Üyeler
5 adet Kılavuz yazıldı
4Kılavuz Yorumları
I have a torn speaker cone. Can these be replaced and where can I buy the parts
rchrdsmmnds - Yanıt
I would like to know where I can buy a replacement speaker for my Google Home. Thanks in advance P.s has anybody else had their speaker blow on them on the Google Home?
Mark Goff - Yanıt
Looking for replacement speaker, where do I find?
Corey Anderson - Yanıt
replacement speaker for google home, someone knows here i find?
model:PLS -50N25AL07-04
or compatible speaker
vinyboylima - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 13
Her zaman: 2,347
