Giriş
This is an outdated guide, the newest version is available here.
The charging assembly contains the USB-C port and is connected to the vibrator. Use this guide to replace the charging assembly.
Neye ihtiyacın var
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. This also makes a smooth surface allowing the suction cup to bond.
Apply a suction cup as close to the volume button edge of the phone as you can while avoiding the curved edge.
Apply a heated iOpener to the proximity sensor on the top edge of the midframe for two minutes to soften its adhesive.
Use the flat end of a spudger to disconnect the battery connector.
Disconnect the white antenna cable.
Disconnect the black antenna cable.
