Ana içeriğe geç
Google Pixel 2 Display Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. Google Pixel 2 Display Replacement, Display: adım 1, 2 resimden 1. Google Pixel 2 Display Replacement, Display: adım 1, 2 resimden 2.
      • Heat up the iOpener in the microwave for 30 seconds.
      • Place the iOpener clear-side down on each edge of the phone for approximately 30 seconds.
      • Place the iOpener on top of the screen for an additional 30 seconds.
      • Be careful with the iOpener as it will get extremely hot.
      FixBot'a Sor
      Yorum Ekle
    2. Google Pixel 2 Display Replacement: adım 2, 3 resimden 1. Google Pixel 2 Display Replacement: adım 2, 3 resimden 2. Google Pixel 2 Display Replacement: adım 2, 3 resimden 3.
      • Attach the suction cup to the display by placing it on top of the display and pushing down on the top of the cup until it is flat.
      • Separate the display and the device by inserting the plastic opening tool between them and sliding the plastic opening tool along the perimeter of the display.
      • It is normal to hear popping noises as the plastic opening tool breaks the connection between the display and the device.
      • Remove the display from the device by grabbing the ring of the suction cup and pulling up.
      FixBot'a Sor
      Yorum Ekle
    3. Google Pixel 2 Display Replacement: adım 3, 3 resimden 1. Google Pixel 2 Display Replacement: adım 3, 3 resimden 2. Google Pixel 2 Display Replacement: adım 3, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the T4 4.0-mm screws from the latch under the display by turning the screwdriver counterclockwise.
      • Pull the latch off of the device by grabbing it with the tweezers and pulling up.
      FixBot'a Sor
      Yorum Ekle
    4. Google Pixel 2 Display Replacement: adım 4, 1 resimden 1.
      • Remove the connector underneath the latch by grabbing it with the tweezers and lifting up.
      • It is normal to hear a popping noise during this step.
      • When reassembling, simply use your finger to pop this piece back into place by pushing it down into the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Monica Andres
289 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G5, Livingston Winter 2018 Cal Poly, Team S18-G5, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G5
4 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,368
