Giriş
This is an outdated guide, go here for the newest version.
The charging assembly contains the USB-C port, microphone, and other hardware. Use this guide to replace the charging assembly.
Neye ihtiyacın var
Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
Press firmly to eject the tray.
Adım 3 Opening Procedure
Dikkatli ol: adımlar 3-14 yapım altında olarak işaretlenen bir kılavuzdan alınmıştır.
Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
Do not cut along the left edge; there are delicate display cables that can be damaged.
Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
Bu adımda kullanılan alet:Magnetic Project Mat$19.95
Remove eleven 3.8 mm Phillips screws securing the midframe.
Use the flat end of a spudger to disconnect the battery connector.
Use the point of a spudger to disconnect the front-facing camera connector.
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
Remove the motherboard.
Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
Disconnect the white antenna cable.
Carefully pry the charging assembly out and remove it from the device.
