Giriş
Prerequisite guide only! This guide is part of an another procedure and is not meant to be used alone.
Disconnects the antenna cables in preparation for motherboard removal.
Neye ihtiyacın var
Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
Use the point of a spudger to pry up and disconnect the black antenna cable from its socket near the USB-C port.
Carefully de-route both antenna cables and move them away from the charging assembly.
