Ana içeriğe geç
Google Pixel 3 Back Cover Adhesive Installation
Neye ihtiyacın var
    1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 3.
      • Pick and scrape away the old adhesive from the frame.
      • Use a spudger to scrape away any lingering adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the frame.
      • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
      FixBot'a Sor
      Yorum Ekle
    2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: adım 2, 3 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: adım 2, 3 resimden 2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: adım 2, 3 resimden 3.
      • Repeat the previous step for the back cover adhesive.
      • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
      • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
      FixBot'a Sor
      Yorum Ekle
    3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: adım 3, 1 resimden 1.
      • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
      FixBot'a Sor
      Yorum Ekle
    4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: adım 4, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: adım 4, 2 resimden 2.
      • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
      • Lower the adhesive onto the frame.
      • Use the rear camera and corners to properly align the adhesive.
      FixBot'a Sor
      Yorum Ekle
    5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: adım 5, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: adım 5, 2 resimden 2.
      • Use the flat end of a spudger or your fingernail to press down on the adhesive.
      • Slide along the perimeter to secure the adhesive to the frame.
      FixBot'a Sor
      Yorum Ekle
    6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: adım 6, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: adım 6, 2 resimden 2.
      • Peel away the blue outer plastic lining on the back cover side of the adhesive.
      FixBot'a Sor
      Yorum Ekle
    7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: adım 7, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: adım 7, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
      • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    8. Google Pixel 3 Back Cover Adhesive Installation: adım 8, 3 resimden 1. Google Pixel 3 Back Cover Adhesive Installation: adım 8, 3 resimden 2. Google Pixel 3 Back Cover Adhesive Installation: adım 8, 3 resimden 3.
      • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
      FixBot'a Sor
      Yorum Ekle
    9. Google Pixel 3 Back Cover Adhesive Installation: adım 9, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation: adım 9, 2 resimden 2.
      • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
      FixBot'a Sor
      Yorum Ekle
    10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: adım 10, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: adım 10, 2 resimden 2.
      • Peel away the red plastic lining to expose the back cover side of the adhesive.
      FixBot'a Sor
      Yorum Ekle
    11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: adım 11, 2 resimden 1. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: adım 11, 2 resimden 2.
      • Lower the back cover onto the frame.
      • Press down on all edges of the back cover to secure it to the frame.
      • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
11 farklı kişi bu kılavuzu tamamladı.
Chayton Ritter
27.165 İtibar
105 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 24
Son 30 gün: 80
Her zaman: 4,649
