Giriş
Follow this guide to remove and replace a broken or cracked screen on the Pixel 3. This procedure is for replacement screens that are not pre-mounted onto a frame. Due to the Pixel’s design, this requires removing the motherboard in order to access to the screen connectors.
This procedure will destructively remove the Pixel 3’s screen. OLEDs cease to work when exposed to oxygen or moisture, and are thus sealed in an airtight encapsulation (this is also why OLED panels turn black underneath a screen crack). It is very difficult to replace the front glass alone— the Pixel’s OLED layers are laminated to the glass.
Heat an iOpener and apply it to the bottom of the phone for one minute.
When prying above the power button, be careful not to insert the pick too deeply, or you will damage the fingerprint sensor cable.
Remove the five Phillips screws securing the wireless charging coil:
Two 1.9 mm screws
Two 4.2 mm screws
One 4.3 mm screw
Remove the wireless charging coil.
Use the point of a spudger to pry up and disconnect the battery connector from its socket near the right edge of the phone.
Remove the two screws securing the camera bracket:
One 4.1 mm Phillips screw
One 4 mm standoff screw
Remove the camera bracket.
Use the point of a spudger to pry up and disconnect the loudspeaker connector from its motherboard socket near the right edge of the phone.
Use the point of a spudger to pry up and disconnect the blue antenna cable from its socket on the charging assembly.
Use the flat end of a spudger to carefully pry up the black tape holding the display flex cable in place, near the right edge of the phone.
Carefully remove the antenna bracket from the top left edge of the phone.
Orient the clips such that the silver side is facing upwards.
The teardrop shaped clips should have their points facing towards the phone edge.
The double-holed clip dips downwards towards the frame's top-right screw hole.
Insert the point of a spudger near the top left corner of the motherboard, right below the rear-facing camera.
Pry up gently to loosen the motherboard, bending all flex cables away to accommodate for the movement.
If the motherboard feels firmly seated, check for any flex cables or screws that may still be connected.
Apply a heated iOpener to the bottom edge of the screen for a minute.
Place a suction cup near the bottom edge of the screen, near the USB-C port.
Lift on the suction cup with strong, steady force to create a gap.
You can also try heating and pulling up a long edge of the phone to gain access.
Insert an opening pick into the gap.
Thread the screen cable and digitizer cable out of their cutouts.
Remove the screen.
Clean all adhesive residue from the phone frame. Adhesive that's left behind may apply uneven pressure against the replacement screen and potentially damage it.
Apply a pre-cut adhesive, or double-sided tape to the phone frame's perimeter.
Peel all plastic liners from the back of the replacement screen to expose the adhesive.
Carefully thread the screen cable and the digitizer cable through the phone frame's cutouts.
Lay the screen onto the frame and place some books on top for an hour to help the screen adhesive bond to the frame.
Repair didn’t go as planned? Check out our Google Pixel 3 Answers community for troubleshooting help.
18 farklı kişi bu kılavuzu tamamladı.
23 Yorum
To change only the screen glass… Do you have to disassemble the whole phone or just steps 39 to 42?
Thanks
Hi Adrián,
The OLED is bonded to the screen glass. Unlike LCDs, trying to remove the glass only will most likely destroy the OLED screen.
How to differentiate between a pre-mounted and a non pre-mounted display? I don’t want to order the wrong part, hence the question.
The pre-mounted part will come with the frame, which is the majority of the phone body. The screen is already stuck affixed to the frame, but you would have to transfer everything else onto it. The display only part looks like a thin panel with adhesive on the back. It would look like this part.
When buying a replacement screen do I need to buy it with a frame?
