Ana içeriğe geç
Google Pixel 3 XL Back Cover Adhesive Installation
Neye ihtiyacın var
  1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the frame: adım 1, 3 resimden 3.
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
  2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: adım 2, 3 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: adım 2, 3 resimden 2. Google Pixel 3 XL Back Cover Adhesive Installation, Remove adhesive residue from the back cover: adım 2, 3 resimden 3.
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
  3. Google Pixel 3 XL Back Cover Adhesive Installation, Prepare the replacement adhesive: adım 3, 1 resimden 1.
    • Peel away the plastic lining to expose the frame side of the replacement adhesive.
  4. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: adım 4, 3 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: adım 4, 3 resimden 2. Google Pixel 3 XL Back Cover Adhesive Installation, Apply the adhesive: adım 4, 3 resimden 3.
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the holes in the frame to properly align the adhesive.
  5. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: adım 5, 3 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: adım 5, 3 resimden 2. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the adhesive to the frame: adım 5, 3 resimden 3.
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
  6. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: adım 6, 3 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: adım 6, 3 resimden 2. Google Pixel 3 XL Back Cover Adhesive Installation, Connect the fingerprint sensor: adım 6, 3 resimden 3.
    • Use tweezers to guide the fingerprint sensor cable into its socket.
    • Press down on the latch to secure it.
  7. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: adım 7, 2 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Peel away the remaining plastic lining: adım 7, 2 resimden 2.
    • Peel away the plastic lining to expose the back cover side of the adhesive.
  8. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: adım 8, 2 resimden 1. Google Pixel 3 XL Back Cover Adhesive Installation, Secure the back cover to the frame: adım 8, 2 resimden 2.
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
Sonuç
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 XL Answers community for help.
5 farklı kişi bu kılavuzu tamamladı.
Chayton Ritter
18.033 İtibar
99 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
6 Üyeler
7.643 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 50
Her zaman: 1,400
