Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
This guide shows how to remove and replace the glass back panel for your Pixel 3 XL.
Depending on your replacement part, you may need to transfer additional parts to your new back panel. This guide includes additional steps to transfer the fingerprint sensor, flash diffuser, and camera bracket to a replacement back panel. Replacing or swapping the NFC antenna is not included in these steps.
  1. Heat an iOpener and apply it to the right edge of the back panel for a minute. A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage. While you wait, note the following areas on the back panel:
    • Heat an iOpener and apply it to the right edge of the back panel for a minute.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the display and internal battery are both susceptible to heat damage.
    • While you wait, note the following areas on the back panel:
    • Strong adhesive—there are large patches of adhesive near the bottom of the phone.
    • Fingerprint sensor cable—be careful not to slice through the cable as you pry
  2. Apply a suction cup to the heated edge of the back panel, as close to the edge as possible. Pull up on the suction cup with strong, steady force to create a gap. Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Apply a suction cup to the heated edge of the back panel, as close to the edge as possible.
    • Pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your phone, this may be difficult. If you are having trouble, apply heat to the edge and try again.
    • Insert the point of an opening pick into the gap.
    Suction cup doesn’t work on severely cracked glass.
    Jeffrey Kongthong - Yanıt
  3. Slide the opening pick along the right edge to slice through the adhesive. The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier. Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
    • Slide the opening pick along the right edge to slice through the adhesive.
    • The adhesive gums up and becomes hard to slice once it cools. If that happens, re-apply heat to the edge to make slicing easier.
    • Once you have sliced through the edge, leave an opening pick in the seam to prevent the adhesive from re-sealing.
  4. Apply a heated iOpener to the bottom of the back panel for a minute.
    • Apply a heated iOpener to the bottom of the back panel for a minute.
  5. Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone. Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat. Leave a pick in the edge to prevent the adhesive from re-sealing.
    • Use an opening pick to slice around the bottom right corner and continue along the bottom edge of the phone.
    • Work slowly as you slice around the corner to prevent the panel from cracking. If the slicing becomes hard, re-apply heat.
    • Leave a pick in the edge to prevent the adhesive from re-sealing.
  6. Continue heating and slicing the remaining edges of the phone. Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again. Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
    • Continue heating and slicing the remaining edges of the phone.
    • Be careful as you slice along the left edge of the phone. If your pick feels like it's stuck near the top, you may have snagged the fingerprint sensor. Retract the pick out of the seam slightly and try again.
    • Be sure to cut through the thick portions of adhesive near the bottom and right edge of the phone.
  7. Gently pry up the right edge of the back panel.
    • Gently pry up the right edge of the back panel.
    • Use an opening pick to slice through any remaining adhesive along the edges.
  8. Swing the right edge of the back panel upwards and rest the flipped panel along the left side of the phone. Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched. During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • Swing the right edge of the back panel upwards and rest the flipped panel along the left side of the phone.
    • Be sure to maintain slack on the fingerprint sensor cable and prevent it from being pinched.
    • During reassembly, this is a good point to power on your phone and test all functions before sealing it up. Be sure to power your phone back down completely before you continue working.
    • During reassembly, follow this guide to install custom-cut adhesives for your back panel.
  9. User tweezers to carefully peel up and remove the yellow tape over the fingerprint sensor connector.
    • User tweezers to carefully peel up and remove the yellow tape over the fingerprint sensor connector.
  10. Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket. Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket. To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
    • Use the point of a spudger to carefully flip up the black lock bar on the fingerprint sensor's ZIF socket.
    • Grasp the cable's tab with your fingers or tweezers and gently walk the flex cable out of the socket.
    • To prevent shorting, be careful not to touch the metal contacts on the flex cable with your tweezers.
  11. Remove the back panel.
    • Remove the back panel.
  12. Apply a heated iOpener over the fingerprint sensor for a minute.
    • Apply a heated iOpener over the fingerprint sensor for a minute.
  13. Insert the edge of an opening tool underneath the square portion of the fingerprint sensor and slowly pry up to loosen the sensor. Continue prying around the perimeter of the fingerprint sensor until it is loosened. Continue prying around the perimeter of the fingerprint sensor until it is loosened.
    • Insert the edge of an opening tool underneath the square portion of the fingerprint sensor and slowly pry up to loosen the sensor.
    • Continue prying around the perimeter of the fingerprint sensor until it is loosened.
  14. From the outer side of the back panel, use your finger to push the fingerprint sensor out of its cutout.
    • From the outer side of the back panel, use your finger to push the fingerprint sensor out of its cutout.
    • Remove the fingerprint sensor.
    • If you are transferring the fingerprint sensor to a new back panel, use some double-sided tape such as Tesa tape to affix it to the new panel.
  15. Insert the edge of an opening tool underneath the plastic flash diffuser and slowly pry up to loosen the diffuser.
    • Insert the edge of an opening tool underneath the plastic flash diffuser and slowly pry up to loosen the diffuser.
    • Remove the diffuser.
  16. Insert the edge of an opening tool underneath the camera bracket and pry up to loosen it.
    • Insert the edge of an opening tool underneath the camera bracket and pry up to loosen it.
    • Remove and transfer the camera bracket to your replacement part.
    • Compare your new replacement back panel to the original part. You may need to transfer additional components or remove adhesive backings from the new part before installing.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Arthur Shi
151.753 İtibar
401 adet Kılavuz yazıldı
Takım
iFixit iFixit üyesi
Community
134 Üyeler
14.937 adet Kılavuz yazıldı
7 Yorum
What’s the flat pice that surrounds the fingerprint sensor? It appears to have two pieces that connect with a terminal on the logic board.
Grant Pauli - Yanıt
Is it the NFC reader?
Grant Pauli -
Correct! That is the NFC coil.
Arthur Shi -
I successfully installed the screen but accidentally broke off the gold tab sticking up from the mother board shield. It can be seen on the picture of step 11 next to the NFC connectors. Do you know what this is for and how it will affect the function of the phone?
Sal Arias - Yanıt
Hi Sal!
That tab looks to be a grounding clip, which would normally touch the fingerprint sensor bracket. I don’t think it is vital for daily function.
Arthur Shi -
I don’t see it addressed in the breakdown but how do you remove the NFC reader from the old back cover ?
kevin brady - Yanıt
Hey Kevin!
The NFC coil is lightly adhered to the back cover. Slowly and carefully peel it off the back cover. You can either apply a heated iOpener or some high-concentration (over 90%) isopropyl alcohol to help loosen the adhesive.
Arthur Shi -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 83
Son 30 gün: 328
Her zaman: 5,241
