Ana içeriğe geç
Google Pixel 3a Plastic Midframe Replacement
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Google Pixel 3a Plastic Midframe Replacement, Plastic Midframe: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    Magnetic Project Mat
    $19.95
    • Remove the fourteen T3 screws of the following lengths securing the plastic midframe:
    • Twelve 4.3 mm silver T3 screws
    • Two 4.3 mm black T3 screws
  2. Google Pixel 3a Plastic Midframe Replacement: adım 2, 3 resimden 1. Google Pixel 3a Plastic Midframe Replacement: adım 2, 3 resimden 2. Google Pixel 3a Plastic Midframe Replacement: adım 2, 3 resimden 3.
    • The midframe is still held in place by plastic clips.
    • Insert an opening pick into frame seam at the bottom of the phone. This seam sits between the plastic midframe and the back cover.
    • Slide the pick along the seam to release the clips holding the plastic midframe.
  3. Google Pixel 3a Plastic Midframe Replacement: adım 3, 3 resimden 1. Google Pixel 3a Plastic Midframe Replacement: adım 3, 3 resimden 2. Google Pixel 3a Plastic Midframe Replacement: adım 3, 3 resimden 3.
    • Slide the opening pick along the left and right edges of the phone to release the midframe clips.
    • Lift the bottom edge of the plastic midframe up but do not remove the midframe. The midframe is still tethered to the phone by the fragile proximity sensor cable at the top edge.
    • To reinstall the plastic midframe, align the midframe to the back cover, and squeeze the perimeter of the phone with your fingers to snap the clips back into position.
  4. Google Pixel 3a Plastic Midframe Replacement: adım 4, 3 resimden 1. Google Pixel 3a Plastic Midframe Replacement: adım 4, 3 resimden 2. Google Pixel 3a Plastic Midframe Replacement: adım 4, 3 resimden 3.
    • Use the point of a spudger to carefully pry up and disconnect the proximity sensor connector from the motherboard.
    • Your proximity sensor connector may have automatically disconnected itself when you lifted the midframe.
    • Remove the plastic midframe.
  5. Google Pixel 3a Plastic Midframe Replacement: adım 5, 3 resimden 1. Google Pixel 3a Plastic Midframe Replacement: adım 5, 3 resimden 2. Google Pixel 3a Plastic Midframe Replacement: adım 5, 3 resimden 3.
    • This step shows how to reconnect the proximity sensor during re-assembly.
    • Align the top edge of the plastic midframe with the phone.
    • Use the point of a spudger to carefully align and push the proximity sensor connector onto the motherboard socket.
    • This takes a bit of patience and finesse. Once you have the connector in place, you can also use a finger to gently press the connector onto the socket.
    • Alternatively, you can remove the proximity sensor from the midframe to reattach it to the motherboard first.
    • Use the point of a spudger to carefully pry the proximity sensor out of its recess on the midframe. The sensor is lightly adhered to the midframe.
    • Remove the sensor from the midframe. Attach the sensor connector onto its motherboard socket.
    • Thread the sensor cable through the midframe and reposition the sensor in the recess. Press down with your finger to adhere the sensor back onto the midframe.
Sonuç
Arthur Shi
317.118 İtibar
730 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
125 Üyeler
24.046 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 14
Her zaman: 218
