Ana içeriğe geç
Google Pixel 7 Camera Glass Replacement
  1. Google Pixel 7 Camera Glass Replacement, Camera Glass: adım 1, 1 resimden 1.
    • Heat the camera glass with a hair dryer to soften the adhesive.
  2. Google Pixel 7 Camera Glass Replacement, Remove the Damaged Glass: adım 2, 1 resimden 1.
    • Using a knife, carefully remove the broken glass covering the camera sensors.
    • After removing all glass, carefully clean the camera lenses with a microfiber cloth. Be cautious of any glass fragments that may remain.
  3. Google Pixel 7 Camera Glass Replacement, Insert the Replacement Glass: adım 3, 2 resimden 1. Google Pixel 7 Camera Glass Replacement, Insert the Replacement Glass: adım 3, 2 resimden 2.
    • Beware that replacement of the glass can cause many problems, specifically with the new adhesive clouding up pictures.
    • Insert the new glass with the adhesive side up (unfortunately, if the adhesive layer faces the camera, the image will be blurry).
  4. Google Pixel 7 Camera Glass Replacement, Apply Full-Surface Protective Glass Cover: adım 4, 1 resimden 1.
    • Put on a full-surface glass protector. Make sure that no dust collects between the cover and the device/camera glass.
Sonuç
Follow the steps in reverse order to reassemble your device
9 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
Peter Schneider
365 İtibar
1 Kılavuz yazıldı
9Kılavuz Yorumları
Moin, könntest du mir nen link zukommen lassen wo du das Kameraglas her hast?
Florian Haß - Yanıt
Hi, beide Gläser sind von Amazon, leider ist das untere, passende Glas momentan nicht lieferbar. Zudem habe ich leider feststellen müssen, dass die Klebeschicht die Qualität negativ beeinflusst. Ich versuche aktuell die Schicht zu entfernen, habe aber noch kein geeignetes Mittel gefunden.
https://www.amazon.de/dp/B0BJFHYFFR?ref=...
https://www.amazon.de/dp/B0BFKDFLZG?ref=...
Peter Schneider -
I did find a link on Amazon (Canadian one) that had the actual lense. It also states in the ad that it doesn't involve taking apart my phone, just do what you did in a sense. I'll post the link for you to check it out if you can and would like to. I'll update you on how it goes for me.
Pixel 7 Glass Lense Replacement Part
Mandie Thomson - Yanıt
It is a big issues. I am also facing same problem I can't replace it because in my country there is no pixel store .
Sushan Khadka - Yanıt
So are you saying that I take the oval glass and place it adhesive up (not down, adhering it to the phone) and then cover with a larger rear screen protector, such that the adhesive holds the oval glass to the inside of the larger screen protector?
I have tried replacing the oval glass by itself with the adhesive down to hold the oval glass to the phone without the larger rear screen protector and the lens will not focus on distance items, i.e. appear blurry as you indicate.
Gerald Biehle - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 226
Son 30 gün: 1,172
Her zaman: 40,044
