Ana içeriğe geç
Google Pixel 8a Back Cover Replacement
Neye ihtiyacın var
  1. Google Pixel 8a Back Cover Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 1. Google Pixel 8a Back Cover Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 2. Google Pixel 8a Back Cover Replacement, Prepare your Pixel for disassembly: adım 1, 3 resimden 3.
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. Google Pixel 8a Back Cover Replacement, Adhesive information: adım 2, 3 resimden 1. Google Pixel 8a Back Cover Replacement, Adhesive information: adım 2, 3 resimden 2. Google Pixel 8a Back Cover Replacement, Adhesive information: adım 2, 3 resimden 3.
    • The back cover is secured with adhesive around the perimeter and near the cameras. To avoid damaging your phone's internals, note the following:
    • Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
    • Don't insert your tool under the edges of the camera bump.
  3. Google Pixel 8a Back Cover Replacement, Insert an opening tool: adım 3, 3 resimden 1. Google Pixel 8a Back Cover Replacement, Insert an opening tool: adım 3, 3 resimden 2. Google Pixel 8a Back Cover Replacement, Insert an opening tool: adım 3, 3 resimden 3.
    • Your opening tool has a flat end and a curved end. During the opening procedure, use the flat end and angle it so the tool's sharp edge points upward.
    • Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
  4. Google Pixel 8a Back Cover Replacement, Separate the perimeter adhesive: adım 4, 3 resimden 1. Google Pixel 8a Back Cover Replacement, Separate the perimeter adhesive: adım 4, 3 resimden 2. Google Pixel 8a Back Cover Replacement, Separate the perimeter adhesive: adım 4, 3 resimden 3.
    • Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
  5. Google Pixel 8a Back Cover Replacement: adım 5, 3 resimden 1. Google Pixel 8a Back Cover Replacement: adım 5, 3 resimden 2. Google Pixel 8a Back Cover Replacement: adım 5, 3 resimden 3.
    • Slide your opening tool around the bottom right corner and up the right edge, stopping at the bottom of the camera bump.
    • Remove your opening tool from under the back cover.
  6. Google Pixel 8a Back Cover Replacement: adım 6, 3 resimden 1. Google Pixel 8a Back Cover Replacement: adım 6, 3 resimden 2. Google Pixel 8a Back Cover Replacement: adım 6, 3 resimden 3.
    • Insert your opening tool under the top right corner of the back cover, just above the camera bump.
    • Slide your opening tool along the top edge, stopping at the top left corner just above the camera bump.
  7. Google Pixel 8a Back Cover Replacement: adım 7, 3 resimden 1. Google Pixel 8a Back Cover Replacement: adım 7, 3 resimden 2. Google Pixel 8a Back Cover Replacement: adım 7, 3 resimden 3.
    • Insert your opening tool under the left edge of the back cover, just below the camera bump.
    • Slide your opening tool down the left edge to separate the adhesive.
  8. Google Pixel 8a Back Cover Replacement, Separate the camera bump adhesive: adım 8, 3 resimden 1. Google Pixel 8a Back Cover Replacement, Separate the camera bump adhesive: adım 8, 3 resimden 2. Google Pixel 8a Back Cover Replacement, Separate the camera bump adhesive: adım 8, 3 resimden 3.
    • A strip of adhesive above the camera bump secures the top edge of the back cover.
    • Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
    • You can insert the opening pick more than 3 mm along the top edge.
    • Slide the pick to the right, stopping when you reach the right edge of the cameras.
  9. Google Pixel 8a Back Cover Replacement: adım 9, 3 resimden 1. Google Pixel 8a Back Cover Replacement: adım 9, 3 resimden 2. Google Pixel 8a Back Cover Replacement: adım 9, 3 resimden 3.
    • A final strip of adhesive below the camera bump secures the back cover.
    • Insert the flat edge of an opening pick under the back cover, just below the camera bump.
    • Insert a second opening pick in the same spot on the other side.
  10. Google Pixel 8a Back Cover Replacement: adım 10, 3 resimden 1. Google Pixel 8a Back Cover Replacement: adım 10, 3 resimden 2. Google Pixel 8a Back Cover Replacement: adım 10, 3 resimden 3.
    • Pry up simultaneously with both picks and apply constant pressure to separate the final piece of adhesive securing the back cover.
    • Be careful not to bend the back cover. If the adhesive feels stubborn, rotate the cover side-to-side to further loosen the adhesive.
    • If the adhesive isn't separating, you can lightly heat the back cover just below the camera bump with a hair dryer or iOpener to soften the adhesive.
  11. Google Pixel 8a Back Cover Replacement, Remove the back cover: adım 11, 2 resimden 1. Google Pixel 8a Back Cover Replacement, Remove the back cover: adım 11, 2 resimden 2.
    • Remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back cover.
Sonuç
To reassemble your device, follow this guide.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
4 farklı kişi bu kılavuzu tamamladı.
Spencer Day
160.130 İtibar
1.045 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.992 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 57
Son 30 gün: 302
Her zaman: 5,955
