Ana içeriğe geç
Google Pixel C Headphone Jack Replacement
Neye ihtiyacın var
    1. Google Pixel C Headphone Jack Replacement, Screen: adım 1, 1 resimden 1.
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      FixBot'a Sor
      Yorum Ekle
    2. Google Pixel C Headphone Jack Replacement: adım 2, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 2, 2 resimden 2.
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      FixBot'a Sor
      Yorum Ekle
    3. Google Pixel C Headphone Jack Replacement: adım 3, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 3, 2 resimden 2.
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      FixBot'a Sor
      Yorum Ekle
    4. Google Pixel C Headphone Jack Replacement: adım 4, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 4, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      FixBot'a Sor
      Yorum Ekle
    1. Google Pixel C Headphone Jack Replacement, Headphone Jack: adım 5, 1 resimden 1.
      • Orient the device so that the headphone jack is in the bottom right corner.
      FixBot'a Sor
      Yorum Ekle
    2. Google Pixel C Headphone Jack Replacement: adım 6, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 6, 2 resimden 2.
      • Remove the two 3.5mm Phillips #000 screws.
      FixBot'a Sor
      Yorum Ekle
    3. Google Pixel C Headphone Jack Replacement: adım 7, 1 resimden 1.
      • Locate and remove the two 2.5mm Phillips #000 screws on either side of the wire coil.
      FixBot'a Sor
      Yorum Ekle
    4. Google Pixel C Headphone Jack Replacement: adım 8, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 8, 2 resimden 2.
      • Detach the red and black cable using a narrow spudger.
      FixBot'a Sor
      Yorum Ekle
    5. Google Pixel C Headphone Jack Replacement: adım 9, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 9, 2 resimden 2.
      • Detach the cable connecting to the headphone jack.
      FixBot'a Sor
      Yorum Ekle
    6. Google Pixel C Headphone Jack Replacement: adım 10, 2 resimden 1. Google Pixel C Headphone Jack Replacement: adım 10, 2 resimden 2.
      • Lift the headphone jack, coiled wire, and cable, peeling the adhesive back.
      • Reassembly will require adhesive to ensure that the components are secured to the device.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Deborah Iwakiri
522 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G4
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 36
Her zaman: 1,384
