Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Google Pixel C Screen Replacement
Neye ihtiyacın var
  1. Google Pixel C Screen Replacement, Screen: adım 1, 1 resimden 1.
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
  2. Google Pixel C Screen Replacement: adım 2, 2 resimden 1. Google Pixel C Screen Replacement: adım 2, 2 resimden 2.
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
  3. Google Pixel C Screen Replacement: adım 3, 2 resimden 1. Google Pixel C Screen Replacement: adım 3, 2 resimden 2.
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
  4. Google Pixel C Screen Replacement: adım 4, 2 resimden 1. Google Pixel C Screen Replacement: adım 4, 2 resimden 2.
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Deborah Iwakiri
522 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017 üyesi
CPSU-LIVINGSTON-S17S21G4
4 Üyeler
11 adet Kılavuz yazıldı
28 Yorum
Where can a replacement screen be located?
Ronnie Williams - Yanıt
Where can i buy a spare screen for this tablet?
Luigi Abbinante - Yanıt
Yes, I have to buy the screen too, but where??
Кирилл Кнышев - Yanıt
All very nice but unfortunately useless without knowing where to get the parts :(
Lorenzo Braschi - Yanıt
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
Luigi Abbinante -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 17,404
