Ana içeriğe geç
Google Pixel Slate Front-Facing Camera Replacement
Neye ihtiyacın var
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: adım 1, 3 resimden 1. Google Pixel Slate Front-Facing Camera Replacement, Screen: adım 1, 3 resimden 2. Google Pixel Slate Front-Facing Camera Replacement, Screen: adım 1, 3 resimden 3.
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Front-Facing Camera Replacement: adım 2, 3 resimden 1. Google Pixel Slate Front-Facing Camera Replacement: adım 2, 3 resimden 2. Google Pixel Slate Front-Facing Camera Replacement: adım 2, 3 resimden 3.
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: adım 3, 3 resimden 1. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: adım 3, 3 resimden 2. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: adım 3, 3 resimden 3.
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: adım 4, 3 resimden 1. Google Pixel Slate Front-Facing Camera Replacement: adım 4, 3 resimden 2. Google Pixel Slate Front-Facing Camera Replacement: adım 4, 3 resimden 3.
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: adım 5, 2 resimden 1. Google Pixel Slate Front-Facing Camera Replacement: adım 5, 2 resimden 2.
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: adım 6, 2 resimden 1. Google Pixel Slate Front-Facing Camera Replacement: adım 6, 2 resimden 2.
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Spencer Alonge
648 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 15
Her zaman: 803
