Ana içeriğe geç
Google Pixel Slate Motherboard Replacement
Neye ihtiyacın var
  1. Google Pixel Slate Motherboard Replacement, Screen: adım 1, 3 resimden 1. Google Pixel Slate Motherboard Replacement, Screen: adım 1, 3 resimden 2. Google Pixel Slate Motherboard Replacement, Screen: adım 1, 3 resimden 3.
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Motherboard Replacement: adım 2, 3 resimden 1. Google Pixel Slate Motherboard Replacement: adım 2, 3 resimden 2. Google Pixel Slate Motherboard Replacement: adım 2, 3 resimden 3.
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Motherboard Replacement, Motherboard: adım 3, 3 resimden 1. Google Pixel Slate Motherboard Replacement, Motherboard: adım 3, 3 resimden 2. Google Pixel Slate Motherboard Replacement, Motherboard: adım 3, 3 resimden 3.
    • Once the screen is removed, remove the two black, adhesive strips.
  4. Google Pixel Slate Motherboard Replacement: adım 4, 3 resimden 1. Google Pixel Slate Motherboard Replacement: adım 4, 3 resimden 2. Google Pixel Slate Motherboard Replacement: adım 4, 3 resimden 3.
    • Use a T3 Torx screwdriver to remove the two black screws that are holding down the copper strip.
  5. Google Pixel Slate Motherboard Replacement: adım 5, 3 resimden 1. Google Pixel Slate Motherboard Replacement: adım 5, 3 resimden 2. Google Pixel Slate Motherboard Replacement: adım 5, 3 resimden 3.
    • Use the T3 Torx screwdriver to remove the seven 3mm screws.
    • Use a T2 Torx screwdriver to remove the pink 2mm screw closest to the edge.
    • There is a total of four blue 3mm screws, two black 3mm screws, one pink 3mm screw, and one pink 2mm screw holding down the plate.
  6. Google Pixel Slate Motherboard Replacement: adım 6, 2 resimden 1. Google Pixel Slate Motherboard Replacement: adım 6, 2 resimden 2.
    • Lift and remove the metal plate.
  7. Google Pixel Slate Motherboard Replacement: adım 7, 3 resimden 1. Google Pixel Slate Motherboard Replacement: adım 7, 3 resimden 2. Google Pixel Slate Motherboard Replacement: adım 7, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the two speaker plugs, one battery plug, and disconnect the four flat wires from the motherboard.
    • Nylon Tipped Tweezers may be necessary to remove the wires effectively.
  8. Google Pixel Slate Motherboard Replacement: adım 8, 3 resimden 1. Google Pixel Slate Motherboard Replacement: adım 8, 3 resimden 2. Google Pixel Slate Motherboard Replacement: adım 8, 3 resimden 3.
    • Use a T3 Torx screwdriver to remove the two silver screws.
    • Remove the 4 exposed washers from the motherboard and put aside.
  9. Google Pixel Slate Motherboard Replacement: adım 9, 3 resimden 1. Google Pixel Slate Motherboard Replacement: adım 9, 3 resimden 2. Google Pixel Slate Motherboard Replacement: adım 9, 3 resimden 3.
    • Use the iFixit opening tool to remove the motherboard from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Spencer Alonge
648 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G5
4 Üyeler
Bir Yorum
Very helpful, nice and clear steps.
Eddie Lundberg - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 20
Son 30 gün: 65
Her zaman: 3,257
