Ana içeriğe geç
Google Pixel Slate Rear-Facing Camera Replacement
Neye ihtiyacın var
  1. Google Pixel Slate Rear-Facing Camera Replacement, Screen: adım 1, 3 resimden 1. Google Pixel Slate Rear-Facing Camera Replacement, Screen: adım 1, 3 resimden 2. Google Pixel Slate Rear-Facing Camera Replacement, Screen: adım 1, 3 resimden 3.
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Rear-Facing Camera Replacement: adım 2, 3 resimden 1. Google Pixel Slate Rear-Facing Camera Replacement: adım 2, 3 resimden 2. Google Pixel Slate Rear-Facing Camera Replacement: adım 2, 3 resimden 3.
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: adım 3, 3 resimden 1. Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: adım 3, 3 resimden 2. Google Pixel Slate Rear-Facing Camera Replacement, Rear-Facing Camera: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a T2 Torx screwdriver to remove the two black 2mm screws holding down the square plate.
    • Use the Nylon Tipped Tweezers to lift the metal plate.
  4. Google Pixel Slate Rear-Facing Camera Replacement: adım 4, 3 resimden 1. Google Pixel Slate Rear-Facing Camera Replacement: adım 4, 3 resimden 2. Google Pixel Slate Rear-Facing Camera Replacement: adım 4, 3 resimden 3.
    • Use a T3 Torx screwdriver to remove the two yellow and grey 3mm screws from the L-shaped plate.
    • Use the Nylon Tipped Tweezers to lift the plate from the device.
  5. Google Pixel Slate Rear-Facing Camera Replacement: adım 5, 2 resimden 1. Google Pixel Slate Rear-Facing Camera Replacement: adım 5, 2 resimden 2.
    • Gently pull upwards to remove the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Spencer Alonge
648 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 528
