Ana içeriğe geç
Google Pixel Slate Speaker Replacement
Neye ihtiyacın var
  1. Google Pixel Slate Speaker Replacement, Screen: adım 1, 3 resimden 1. Google Pixel Slate Speaker Replacement, Screen: adım 1, 3 resimden 2. Google Pixel Slate Speaker Replacement, Screen: adım 1, 3 resimden 3.
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
  2. Google Pixel Slate Speaker Replacement: adım 2, 3 resimden 1. Google Pixel Slate Speaker Replacement: adım 2, 3 resimden 2. Google Pixel Slate Speaker Replacement: adım 2, 3 resimden 3.
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
  3. Google Pixel Slate Speaker Replacement, Speaker: adım 3, 3 resimden 1. Google Pixel Slate Speaker Replacement, Speaker: adım 3, 3 resimden 2. Google Pixel Slate Speaker Replacement, Speaker: adım 3, 3 resimden 3.
    • There are two speakers, one on each side of the Google Pixel Slate. This guide works for either one.
    • Use the T2 Torx screwdriver to remove the yellow 2mm screw from the thin metal plate.
    • Use the T3 Torx screwdriver to remove the pink 3mm screw from the thin metal plate.
    • Remove the thin metal plate from the device.
  4. Google Pixel Slate Speaker Replacement: adım 4, 1 resimden 1.
    • Use the T2 Torx screwdriver to remove the two black 2mm screws from the speaker.
  5. Google Pixel Slate Speaker Replacement: adım 5, 2 resimden 1. Google Pixel Slate Speaker Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use the Nylon-Tipped Tweezers to remove the black plug.
    • There is a red and a black wire connected to the black plug.
    • Pull the black plug in an upwards direction.
    • Be sure to gently remove plug, as using too much force can damage the connecting wires.
  6. Google Pixel Slate Speaker Replacement: adım 6, 2 resimden 1. Google Pixel Slate Speaker Replacement: adım 6, 2 resimden 2.
    • Use the Nylon-Tipped Tweezers to disconnect the black tape-like plug connected to the speaker.
  7. Google Pixel Slate Speaker Replacement: adım 7, 2 resimden 1. Google Pixel Slate Speaker Replacement: adım 7, 2 resimden 2.
    • Detach the speaker wire from the motherboard.
    • Remove the adhesive strips that hold down the speaker wire.
  8. Google Pixel Slate Speaker Replacement: adım 8, 3 resimden 1. Google Pixel Slate Speaker Replacement: adım 8, 3 resimden 2. Google Pixel Slate Speaker Replacement: adım 8, 3 resimden 3.
    • Use the T2 Torx screwdriver to remove the 2mm black screw from the brass plate.
    • Pull back the brass plate.
  9. Google Pixel Slate Speaker Replacement: adım 9, 1 resimden 1.
    • You can now remove the speaker from the device.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Spencer Alonge
648 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S2-G5, Maness Spring 2019 Cal Poly, Team S2-G5, Maness Spring 2019 üyesi
CPSU-MANESS-S19S2G5
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 889
