Giriş
In this guide, you will learn how to replace the left charging port on your Google Pixelbook to fix charging issues.
Neye ihtiyacın var
Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
Peel the linings off completely until the back of the Pixelbook looks bare.
Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
Bir başkası bu kılavuzu tamamladı.
3Kılavuz Yorumları
Where to get replacemt charging port from please
Where can we get a replacement charging port for the Pixelbook Go 2 (i7)?
Hi Michael, did you manage to find the charging port and replace it for the Pixelbook Go?
