Ana içeriğe geç
Google Pixelbook Motherboard Replacement
Neye ihtiyacın var
  1. Google Pixelbook Motherboard Replacement, Battery (Back Panel): adım 1, 3 resimden 1. Google Pixelbook Motherboard Replacement, Battery (Back Panel): adım 1, 3 resimden 2. Google Pixelbook Motherboard Replacement, Battery (Back Panel): adım 1, 3 resimden 3.
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    FixBot'a Sor
    Yorum Ekle
  2. Google Pixelbook Motherboard Replacement: adım 2, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Google Pixelbook Motherboard Replacement: adım 3, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 3, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 3, 3 resimden 3.
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    FixBot'a Sor
    Yorum Ekle
  4. Google Pixelbook Motherboard Replacement: adım 4, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 4, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 4, 3 resimden 3.
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    FixBot'a Sor
    Yorum Ekle
  5. Google Pixelbook Motherboard Replacement: adım 5, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 5, 2 resimden 2.
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  6. Google Pixelbook Motherboard Replacement: adım 6, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 6, 2 resimden 2.
    • Remove the small, black casing by using the spudger to lift it up from its place.
    FixBot'a Sor
    Yorum Ekle
  7. Google Pixelbook Motherboard Replacement: adım 7, 1 resimden 1.
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    FixBot'a Sor
    Yorum Ekle
  8. Google Pixelbook Motherboard Replacement, Left Charging Port: adım 8, 2 resimden 1. Google Pixelbook Motherboard Replacement, Left Charging Port: adım 8, 2 resimden 2.
    • Remove the two 3.0mm silver screws from the thin, black component by using a T3 Torx screwdriver to turn the screws counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  9. Google Pixelbook Motherboard Replacement: adım 9, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 9, 2 resimden 2.
    • Disconnect the thin, black and white cord from the motherboard by using the spudger to snap the connector up and out of place.
    FixBot'a Sor
    Yorum Ekle
  10. Google Pixelbook Motherboard Replacement: adım 10, 1 resimden 1.
    • Remove the thin, black component by pulling it up and out of the laptop with your fingers.
    • This photo shows the bottom screw still in the black box, but yours should be removed.
    FixBot'a Sor
    Yorum Ekle
  11. Google Pixelbook Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the gold 2.0mm corner screw by turning it counterclockwise with a T3 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  12. Google Pixelbook Motherboard Replacement: adım 12, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Using needle-nose tweezers, remove the silver casing by lifting it up and out of the computer.
    FixBot'a Sor
    Yorum Ekle
  13. Google Pixelbook Motherboard Replacement: adım 13, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the three 3.0mm black screws on the right side by using a T5 Torx screwdriver to turn the screws counterclockwise.
    • Remove the silver 2.0mm screw on the left side by using a T3 Torx screwdriver to turn the screw counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  14. Google Pixelbook Motherboard Replacement: adım 14, 1 resimden 1.
    • Disconnect the thin, black ribbon cable by using the spudger to lift it up from the computer.
    FixBot'a Sor
    Yorum Ekle
  15. Google Pixelbook Motherboard Replacement: adım 15, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 15, 2 resimden 2.
    • Use the needle-nose tweezers to remove the charging port by lifting the component up and out of the Pixelbook.
    FixBot'a Sor
    Yorum Ekle
  16. Google Pixelbook Motherboard Replacement, Right Charging Port: adım 16, 2 resimden 1. Google Pixelbook Motherboard Replacement, Right Charging Port: adım 16, 2 resimden 2.
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  17. Google Pixelbook Motherboard Replacement: adım 17, 1 resimden 1.
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
    FixBot'a Sor
    Yorum Ekle
  18. Google Pixelbook Motherboard Replacement: adım 18, 1 resimden 1.
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  19. Google Pixelbook Motherboard Replacement: adım 19, 1 resimden 1.
    • Remove the small, red component by lifting it up with the spudger.
    FixBot'a Sor
    Yorum Ekle
  20. Google Pixelbook Motherboard Replacement: adım 20, 1 resimden 1.
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
    FixBot'a Sor
    Yorum Ekle
  21. Google Pixelbook Motherboard Replacement: adım 21, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 21, 2 resimden 2.
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
    FixBot'a Sor
    Yorum Ekle
  22. Google Pixelbook Motherboard Replacement, Motherboard: adım 22, 2 resimden 1. Google Pixelbook Motherboard Replacement, Motherboard: adım 22, 2 resimden 2.
    • Disconnect the flat, black cord from the motherboard by using a spudger to push it upwards out of the slot, or by using your hand to carefully pull upward.
    FixBot'a Sor
    Yorum Ekle
  23. Google Pixelbook Motherboard Replacement: adım 23, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 23, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 23, 3 resimden 3.
    • Fold back the plastic covering on the motherboard using the nylon spudger.
    FixBot'a Sor
    Yorum Ekle
  24. Google Pixelbook Motherboard Replacement: adım 24, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 24, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 24, 3 resimden 3.
    • Disconnect the two black cables from the motherboard by pulling the connectors upward using the needle-nose tweezers.
    FixBot'a Sor
    Yorum Ekle
  25. Google Pixelbook Motherboard Replacement: adım 25, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 25, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 25, 3 resimden 3.
    • Disconnect the flat ribbon cable from the motherboard by using your hand to gently pull it out of the socket, or by using a pair of tweezers to pull it out.
    FixBot'a Sor
    Yorum Ekle
  26. Google Pixelbook Motherboard Replacement: adım 26, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 26, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 26, 3 resimden 3.
    • Disconnect the large flat ribbon cable from the motherboard by using your hand to gently pull it out of the socket, or by using a pair of tweezers to pull it out.
    FixBot'a Sor
    Yorum Ekle
  27. Google Pixelbook Motherboard Replacement: adım 27, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 27, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 27, 3 resimden 3.
    • Raise the retaining latch of the motherboard connector by using the needle-nose tweezers.
    • Disconnect the large flat cable from the motherboard by gently pulling on the latch using the needle-nose tweezers.
    FixBot'a Sor
    Yorum Ekle
  28. Google Pixelbook Motherboard Replacement: adım 28, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 28, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 28, 3 resimden 3.
    • Disconnect the flat cable from the motherboard by using the needle-nose tweezers to gently pull the connector out of the slot.
    FixBot'a Sor
    Yorum Ekle
  29. Google Pixelbook Motherboard Replacement: adım 29, 2 resimden 1. Google Pixelbook Motherboard Replacement: adım 29, 2 resimden 2.
    • Remove the gold 3.0mm screws and the black, flat 2.0mm screws from the motherboard by using a T3 Torx screwdriver to turn the screws counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  30. Google Pixelbook Motherboard Replacement: adım 30, 3 resimden 1. Google Pixelbook Motherboard Replacement: adım 30, 3 resimden 2. Google Pixelbook Motherboard Replacement: adım 30, 3 resimden 3.
    • Remove the motherboard by gently lifting it out of the laptop using the needle-nose tweezers.
    FixBot'a Sor
    Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Logan Lawson
410 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G1
4 Üyeler
9 adet Kılavuz yazıldı
14Kılavuz Yorumları
This would be much more helpful if all the “components” being removed were identified.
TIA,
R
rocwoof - Yanıt Paylaş
You’ve put together a very good procedure for replacing a motherboard. My pixelbook needs a motherboard. Where can I buy one? Google does not sell them.
Tony Meier - Yanıt Paylaş
I believe the step8 & step16 mentioned “charging port“ shall be the loudspeaker in fact.
baokai zheng - Yanıt Paylaş
It’s bad instruction to pull cable out without unlocking the retaining tab, also it’s impossible to put cable back while the connector is still in locking position. Never pull a cable while it’s locked in the connector, this practice is only used by novices.
nabe_03 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 23
Son 30 gün: 97
Her zaman: 16,583
