Ana içeriğe geç
Google Pixelbook Right Charging Port Replacement
  1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): adım 1, 3 resimden 1. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): adım 1, 3 resimden 2. Google Pixelbook Right Charging Port Replacement, Battery (Back Panel): adım 1, 3 resimden 3.
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
  2. Google Pixelbook Right Charging Port Replacement: adım 2, 2 resimden 1. Google Pixelbook Right Charging Port Replacement: adım 2, 2 resimden 2.
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
  3. Google Pixelbook Right Charging Port Replacement: adım 3, 3 resimden 1. Google Pixelbook Right Charging Port Replacement: adım 3, 3 resimden 2. Google Pixelbook Right Charging Port Replacement: adım 3, 3 resimden 3.
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
  4. Google Pixelbook Right Charging Port Replacement: adım 4, 3 resimden 1. Google Pixelbook Right Charging Port Replacement: adım 4, 3 resimden 2. Google Pixelbook Right Charging Port Replacement: adım 4, 3 resimden 3.
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
  5. Google Pixelbook Right Charging Port Replacement: adım 5, 2 resimden 1. Google Pixelbook Right Charging Port Replacement: adım 5, 2 resimden 2.
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
  6. Google Pixelbook Right Charging Port Replacement: adım 6, 2 resimden 1. Google Pixelbook Right Charging Port Replacement: adım 6, 2 resimden 2.
    • Remove the small, black casing by using the spudger to lift it up from its place.
  7. Google Pixelbook Right Charging Port Replacement: adım 7, 1 resimden 1.
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
  8. Google Pixelbook Right Charging Port Replacement, Right Charging Port: adım 8, 2 resimden 1. Google Pixelbook Right Charging Port Replacement, Right Charging Port: adım 8, 2 resimden 2.
    • Remove the three 2.0mm black screws from the sound card by using a T5 Torx screwdriver to turn them counterclockwise.
    • Remove the gold 3.0mm screw by using a T3 Torx screwdriver to turn it counterclockwise.
  9. Google Pixelbook Right Charging Port Replacement: adım 9, 1 resimden 1.
    • Disconect the thin, black and red cord from the motherboard by using the spudger to snap the connector up and out of place.
  10. Google Pixelbook Right Charging Port Replacement: adım 10, 1 resimden 1.
    • Remove the yellow 2.0mm screw by using the T3 Torx screwdriver to turn the screw counterclockwise.
  11. Google Pixelbook Right Charging Port Replacement: adım 11, 1 resimden 1.
    • Remove the small, red component by lifting it up with the spudger.
  12. Google Pixelbook Right Charging Port Replacement: adım 12, 1 resimden 1.
    • Disconnect the metal component of the thin, black component by lifting it up with the spudger.
  13. Google Pixelbook Right Charging Port Replacement: adım 13, 2 resimden 1. Google Pixelbook Right Charging Port Replacement: adım 13, 2 resimden 2.
    • Remove the right charging port by picking it up with the tweezers and lifting it from the computer.
Sonuç
Alon Gary
505 İtibar
2 adet Kılavuz yazıldı
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G1
4 Üyeler
7 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,433
