Ana içeriğe geç
Google Pixelbook Touchpad Replacement
Neye ihtiyacın var
  1. Google Pixelbook Touchpad Replacement, Battery (Back Panel): adım 1, 3 resimden 1. Google Pixelbook Touchpad Replacement, Battery (Back Panel): adım 1, 3 resimden 2. Google Pixelbook Touchpad Replacement, Battery (Back Panel): adım 1, 3 resimden 3.
    • Use the iFixit opening tools or a metal spudger to pry the rubber covers off the back of your Pixelbook.
    • Peel the linings off completely until the back of the Pixelbook looks bare.
    FixBot'a Sor
    Yorum Ekle
  2. Google Pixelbook Touchpad Replacement: adım 2, 2 resimden 1. Google Pixelbook Touchpad Replacement: adım 2, 2 resimden 2.
    • Remove the two yellow 2.0mm screws by using a T3 Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Google Pixelbook Touchpad Replacement: adım 3, 3 resimden 1. Google Pixelbook Touchpad Replacement: adım 3, 3 resimden 2. Google Pixelbook Touchpad Replacement: adım 3, 3 resimden 3.
    • Remove the seventeen 3.0mm T5 Torx screws from the bottom panel.
    FixBot'a Sor
    Yorum Ekle
  4. Google Pixelbook Touchpad Replacement: adım 4, 3 resimden 1. Google Pixelbook Touchpad Replacement: adım 4, 3 resimden 2. Google Pixelbook Touchpad Replacement: adım 4, 3 resimden 3.
    • Use the nylon spudger to pry the edge of the Pixelbook up until you can grab the edge with your fingers.
    • Open the back panel completely and lay it flat so you see the whole inside of the computer.
    FixBot'a Sor
    Yorum Ekle
  5. Google Pixelbook Touchpad Replacement: adım 5, 2 resimden 1. Google Pixelbook Touchpad Replacement: adım 5, 2 resimden 2.
    • Remove the yellow 2.0mm screw from the middle of the panel by using the T3 Torx screwdriver to turn the screw counterclockwise.
    FixBot'a Sor
    Yorum Ekle
  6. Google Pixelbook Touchpad Replacement: adım 6, 2 resimden 1. Google Pixelbook Touchpad Replacement: adım 6, 2 resimden 2.
    • Remove the small, black casing by using the spudger to lift it up from its place.
    FixBot'a Sor
    Yorum Ekle
  7. Google Pixelbook Touchpad Replacement: adım 7, 1 resimden 1.
    • Disconnect the flat, black cord from the main component by using a spudger to push it out of the slot, or by using your hand to carefully pull it out.
    • Your back panel is now free from the main component.
    FixBot'a Sor
    Yorum Ekle
  8. Google Pixelbook Touchpad Replacement, Touchpad: adım 8, 3 resimden 1. Google Pixelbook Touchpad Replacement, Touchpad: adım 8, 3 resimden 2. Google Pixelbook Touchpad Replacement, Touchpad: adım 8, 3 resimden 3.
    • Once the back panel is out of the way, use the T3 Torx screwdriver to turn both the 2.0mm and large 3.0mm gold screws from the touchpad.
    FixBot'a Sor
    Yorum Ekle
  9. Google Pixelbook Touchpad Replacement: adım 9, 3 resimden 1. Google Pixelbook Touchpad Replacement: adım 9, 3 resimden 2. Google Pixelbook Touchpad Replacement: adım 9, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Gently pull out the ribbon connector either by using tweezers or your fingers to pull the cord out and up.
    FixBot'a Sor
    Yorum Ekle
  10. Google Pixelbook Touchpad Replacement: adım 10, 2 resimden 1. Google Pixelbook Touchpad Replacement: adım 10, 2 resimden 2.
    • Use the nylon spudger to push the touchpad out of the laptop by inserting the point into the hole near the edge of the laptop.
    • As the metal plates with the screws tilt upwards, use your hand to catch the falling touchpad and remove it.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Derrick Unger
361 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, Livingston Winter 2018 Cal Poly, Team S18-G1, Livingston Winter 2018 üyesi
CPSU-LIVINGSTON-W18S18G1
4 Üyeler
9 adet Kılavuz yazıldı
6Kılavuz Yorumları
Hello, I followed this guide and no the pixelbook will no longer power on. I reassembled exactly as described here. No light is coming on when I plu in the official charger, have tried other chargers as well. Any suggestions? I’ve been holding refresh + power and ESC but no change. Thanks…
saynotohotmail - Yanıt Paylaş
lol $@$*…that’s reassuring ^^^ I was just about to order a replacement. Did you ever get it to turn back on? Or figure out what you did wrong lol?
Avh - Yanıt Paylaş
What I read after the fact is that if you don’t do a full power off (hold refresh and power for 5 seconds until it is completely off) then the process here could short the motherboard. Which in my case it did. And I really wish these instructions had included something about that.
Ah I see! I just performed it last night actually, I did a regular shutdown via the “shutdown” button in the settings, everything went just fine luckily. Check out the corrosion that was causing my issue! http://imgur.com/gallery/cCfuGh2
In my settings under "devices" I didn't even have an option named “trackpad" - and that would be why,
Avh - Yanıt Paylaş
Can anyone direct me to a source for a replacement touchpad? Thanks.
jacrider - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 53
Her zaman: 5,224
