Ana içeriğe geç
Gourmia GAF536 Handle Replacement
Neye ihtiyacın var
    1. Gourmia GAF536 Handle Replacement, Handle: adım 1, 2 resimden 1. Gourmia GAF536 Handle Replacement, Handle: adım 1, 2 resimden 2.
      • Make sure the device is turned off and let it cool down.
      • Remove the basket and tray from your air fryer.
      FixBot'a Sor
      Yorum Ekle
    2. Gourmia GAF536 Handle Replacement: adım 2, 3 resimden 1. Gourmia GAF536 Handle Replacement: adım 2, 3 resimden 2. Gourmia GAF536 Handle Replacement: adım 2, 3 resimden 3.
      • Locate the screws inside the basket.
      • 4x PH02 Screws: 15mm x 5mm
      FixBot'a Sor
      Yorum Ekle
    3. Gourmia GAF536 Handle Replacement: adım 3, 3 resimden 1. Gourmia GAF536 Handle Replacement: adım 3, 3 resimden 2. Gourmia GAF536 Handle Replacement: adım 3, 3 resimden 3.
      • Once the screws are removed separate the handle from the basket.
      • Locate the single screw on the handle.
      • 1x PH02 Screw: 15mm x 5mm
      FixBot'a Sor
      Yorum Ekle
    4. Gourmia GAF536 Handle Replacement: adım 4, 3 resimden 1. Gourmia GAF536 Handle Replacement: adım 4, 3 resimden 2. Gourmia GAF536 Handle Replacement: adım 4, 3 resimden 3.
      • Remove the screw.
      • Gently pull on the handle with the force needed.
      FixBot'a Sor
      Yorum Ekle
    5. Gourmia GAF536 Handle Replacement: adım 5, 1 resimden 1.
      • After following these steps you will successful remove the handle.
      • Make sure you have all the equipment when going to replace the handle.
      FixBot'a Sor
      Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
Surprised they dont do a recall! The screws can potentially work itself out and unto the food
Jo Avridge - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 12
Son 30 gün: 67
Her zaman: 1,777
