Ana içeriğe geç
Gourmia GAF536 Screen Circuit Board Replacement
Neye ihtiyacın var
  1. Gourmia GAF536 Screen Circuit Board Replacement, Grey Top: adım 1, 1 resimden 1.
    • Use blue opening tool to pry open one side of grey top
    • If there is a loud pop, it is not broken.
  2. Gourmia GAF536 Screen Circuit Board Replacement: adım 2, 1 resimden 1.
    • Pry open all four sides.
  3. Gourmia GAF536 Screen Circuit Board Replacement: adım 3, 1 resimden 1.
    • Remove grey top.
  4. Gourmia GAF536 Screen Circuit Board Replacement, Screen Circuit Board: adım 4, 1 resimden 1.
    • Make sure hat that your air-fryer is turned-off and unplugged to prevent electrical shock.
    • Locate the internal tabs that hold the screen in place. (There should be 2 tabs on top, 2 tabs on the bottom, and 1 on each side.)
    • Focus on the side tabs.
  5. Gourmia GAF536 Screen Circuit Board Replacement: adım 5, 3 resimden 1. Gourmia GAF536 Screen Circuit Board Replacement: adım 5, 3 resimden 2. Gourmia GAF536 Screen Circuit Board Replacement: adım 5, 3 resimden 3.
    • Using your finger or the metal sludger, release the tab on the side.
    • Gently push the open side forward and place the blue opener into the gap from the front.
    • Repeat this on the other side.
  6. Gourmia GAF536 Screen Circuit Board Replacement: adım 6, 2 resimden 1. Gourmia GAF536 Screen Circuit Board Replacement: adım 6, 2 resimden 2.
    • Once both sides of the screen have a blue opener, the screen can be safely popped out.
  7. Gourmia GAF536 Screen Circuit Board Replacement: adım 7, 3 resimden 1. Gourmia GAF536 Screen Circuit Board Replacement: adım 7, 3 resimden 2. Gourmia GAF536 Screen Circuit Board Replacement: adım 7, 3 resimden 3.
    • Remove the cable connecting the circuit board to the air-fryer’s motherboard by gently pinching the tab on the side connected to the screen.
  8. Gourmia GAF536 Screen Circuit Board Replacement: adım 8, 2 resimden 1. Gourmia GAF536 Screen Circuit Board Replacement: adım 8, 2 resimden 2.
    • Remove all of the screws that attach the circuit board to the display screen and casing.
    • 7x PH 02 Screws: 5mm x 10 mm.
  9. Gourmia GAF536 Screen Circuit Board Replacement: adım 9, 2 resimden 1. Gourmia GAF536 Screen Circuit Board Replacement: adım 9, 2 resimden 2.
    • The circuit board can now be detached from the display screen, removed from the plastic casing, and replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Hannah Fisher
309 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 54
Her zaman: 367
