Giriş
This guide will provide the procedure required to replace the Gourmia GAF536 air-fryer screen circuit board.
This control board is the part that allows your screen and buttons to work, as well as connect the screen to the air-fryer’s motherboard. By replacing this part, the following issues can possibly be fixed:
- The device not powering on
- The fryer not reaching the desired temperature
- The fan not running
Because this part is connected to the power, it is best to ensure the device is unplugged before attempting the repair.
Neye ihtiyacın var
Locate the internal tabs that hold the screen in place. (There should be 2 tabs on top, 2 tabs on the bottom, and 1 on each side.)
Bir başkası bu kılavuzu tamamladı.
