Ana içeriğe geç
Governor Adjustment
Neye ihtiyacın var
  1. Governor Adjustment, Governor Adjustment: adım 1, 3 resimden 1. Governor Adjustment, Governor Adjustment: adım 1, 3 resimden 2. Governor Adjustment, Governor Adjustment: adım 1, 3 resimden 3.
    • Before starting, make sure the engine isn't running and is not hot.
    • Using needle-nose pliers, carefully unhook the spring from the end opposite the air filter.
    FixBot'a Sor
  2. Governor Adjustment: adım 2, 1 resimden 1.
    • Use the needle-nose pliers to either lengthen or shorten the hook at the end of the spring.
    • If your engine is stalling or refusing to start, try shortening the spring. This will enable more fuel to reach to engine at idle. If the engine is bogged down when running and you hear liquids splashing, try lengthening the spring.
    FixBot'a Sor
  3. Governor Adjustment: adım 3, 1 resimden 1.
    • Carefully re-hook the spring on the arm it was disconnected from.
    FixBot'a Sor
Sonuç
Aaron Correya
239 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S25-G15, Maness Spring 2018 Cal Poly, Team S25-G15, Maness Spring 2018 üyesi
CPSU-MANESS-S18S25G15
4 Üyeler
7 adet Kılavuz yazıldı
2Kılavuz Yorumları
Wow, I'm very grateful.
Bradley Earnest - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 14
Son 30 gün: 85
Her zaman: 3,238
