Ana içeriğe geç
Grace Digital Mondo Display Cover Replacement
Neye ihtiyacın var
  1. Grace Digital Mondo Display Cover Replacement, Front Panel: adım 1, 1 resimden 1.
    • Remove (2) screws (14 mm) with a PH1 screwdriver on the device.
    • There is one screw on the back left, and another just below it on the bottom of the device.
  2. Grace Digital Mondo Display Cover Replacement: adım 2, 2 resimden 1. Grace Digital Mondo Display Cover Replacement: adım 2, 2 resimden 2.
    • Use a plastic spudger to remove the front preset selection buttons.
    • We recommend you remove all of them for easier access.
    • Gently reach underneath and pull off the mesh speaker cover. It only clips in so don't worry about breaking anything.
  3. Grace Digital Mondo Display Cover Replacement: adım 3, 1 resimden 1.
    • Remove (4) screws (14 mm) with a PH1 screwdriver on the front panel by the speaker.
    • Be careful with these screws, as they can be stripped easily.
  4. Grace Digital Mondo Display Cover Replacement: adım 4, 1 resimden 1.
    • Move the metal spudger around the front panel to remove any adhesive attaching the front panel to the device.
    • Pull apart the front panel from the device with help from the metal spudger.
  5. Grace Digital Mondo Display Cover Replacement: adım 5, 3 resimden 1. Grace Digital Mondo Display Cover Replacement: adım 5, 3 resimden 2. Grace Digital Mondo Display Cover Replacement: adım 5, 3 resimden 3.
    • Detach a pin connector at the top of the device using a metal spudger to open up the inner components.
    • Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
  6. Grace Digital Mondo Display Cover Replacement, Display Cover: adım 6, 1 resimden 1.
    • Remove (10) screws (7 mm) with a PH1 screwdriver on the motherboard.
  7. Grace Digital Mondo Display Cover Replacement: adım 7, 1 resimden 1.
    • Separate the display and motherboard from the front panel of the device.
    • Remove the display glass.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Nathaniel Brabham
431 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-3, Eyestone Spring 2016 USF Tampa, Team 6-3, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S6G3
4 Üyeler
8 adet Kılavuz yazıldı
5 Yorum
Has anyone had to replace the digital volume control? Mine is intermittent. PCB solder joints all look good. I guess I will have to un-solder it to hopefully find a part number.
Richard Smith - Yanıt
Has anyone had to replace the rotary encoder volume control? Mine is intermittent. PCB solder joints all look good. I guess I will have to un-solder it to hopefully find a part number.
EDIT: No markings on it, but one on Ebay seems close enough to try. The shaft looks a little longer than the original. http://www.ebay.com/itm/2PCS-Rotary-enco...
I’m experiencing the same issue with the volume control. Did you use this rotary encoder from Ebay and if so how did it work out?
Dan Gacek -
I used this procedure to install a phone jack that had more volume. It is hooked to the speaker with a switching jack. I just needed a little more volume. The above pictures made it possible to disassemble. I would have been lost without it.
Thanks
ironabby - Yanıt
Mine just stopped working (not turning on.) Wall plug/charger light lights up. Anyone else have this issue? Any solutions to fix it?
TS Project - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 1,062
