Ana içeriğe geç
Graco Paint Sprayers 17C325 2015 Gun Filter Replacement
Neye ihtiyacın var
  1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: adım 1, 3 resimden 1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: adım 1, 3 resimden 2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: adım 1, 3 resimden 3.
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun.
    • Unscrew and remove the handle from the spray gun body.
    • You may need to use a pipe wrench to loosen the handle before removing it.
  2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: adım 2, 3 resimden 1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: adım 2, 3 resimden 2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: adım 2, 3 resimden 3.
    • Use your fingers to remove the blue-tipped filter from the inside of the handle.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
36.084 İtibar
82 adet Kılavuz yazıldı
3 Yorum
It would be beneficial to have the part numbers in this information as well! Otherwise, great job! Thanks
JANET - Yanıt
part number for the gun filter??????
BRITTINEY - Yanıt
288749 60 mesh gun filter
RICHARD -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 11
Son 30 gün: 54
Her zaman: 1,994
