Ana içeriğe geç
Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement
Neye ihtiyacın var
  1. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement, Pump Hose 288623: adım 1, 2 resimden 1. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement, Pump Hose 288623: adım 1, 2 resimden 2.
    • Remove 2 bolts holding the cover on
  2. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: adım 2, 1 resimden 1.
    • Remove hose 288623
  3. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: adım 3, 2 resimden 1. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: adım 3, 2 resimden 2.
    • Connect bottom hose to pump hose without locking it in all the way. Pulling hard you will pull the top portion of the hose through and feed it all the way over to the right locked in place
  4. Graco Paint Sprayers 17P189 2017 Pump Hose 288623 Replacement: adım 4, 1 resimden 1.
    • With the top hose attached make sure to feed around both ends of the pully and pull bottom hose through and push all the way to the right
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Trevor A
1.360 İtibar
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
What do i do with the hose plate, throw it away?
JOSEPH - Yanıt
No, It holds the Hose Coupler in place, not allowing it to wiggle when machine in operation.
MAURICIO - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 75
Her zaman: 2,368
