Ana içeriğe geç
Graco Secure Coverage Speaker Replacement on Parent Unit
Neye ihtiyacın var
  1. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Battery: adım 1, 3 resimden 1. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Battery: adım 1, 3 resimden 2. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Battery: adım 1, 3 resimden 3.
    • Using plastic opening tool, pry and remove the battery lid.
  2. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 2, 1 resimden 1.
    • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
    • Make sure that you disconnect the battery's wire before you remove the battery.
  3. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Speaker: adım 3, 2 resimden 1. Graco Secure Coverage  Speaker Replacement on Parent Unit, Parent Unit Speaker: adım 3, 2 resimden 2.
    • There are two screws on the rare case of the device. For the one shown in red marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
  4. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 4, 2 resimden 1. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 4, 2 resimden 2.
    • Using opening plastic tool, pry the two grey cases from both sides of the device.
    • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
    • While pry off the grey cases, hold the device with your other hand to remove the cases.
  5. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 5, 1 resimden 1.
    • Pry the edges of the device to separate the front case away from the rare case.
    • While prying the edges, hold the device with one hand to pull out each case a part.
    • Make sure you use a constant force, and the pushbuttons are pried off completely.
  6. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 6, 2 resimden 1. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 6, 2 resimden 2.
    • Remove the 7mm Phillips #1 screw from the mother board.
    • Place the screw in a secure place.
    • Pull out the mother board away from the case carefully.
  7. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 7, 2 resimden 1. Graco Secure Coverage  Speaker Replacement on Parent Unit: adım 7, 2 resimden 2.
    • Pick up the motherboard.
    • Solder off the speaker from the device's case.
    • Solder off the speaker from the mother board.
    • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the speaker wires.
    • Replace the speaker.
Sonuç
Ahmed Elshaer
201 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S6G5
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 197
