Ana içeriğe geç
Graco Secure Coverage LED Parent Unit Replacement
Neye ihtiyacın var
    1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: adım 1, 3 resimden 1. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: adım 1, 3 resimden 2. Graco Secure Coverage LED Parent Unit Replacement, Parent Unit Battery: adım 1, 3 resimden 3.
      • Using plastic opening tool, pry and remove the battery lid.
      FixBot'a Sor
      Yorum Ekle
    2. Graco Secure Coverage LED Parent Unit Replacement: adım 2, 1 resimden 1.
      • Remove the battery by holding the device with one hand and pulling the battery out with other hand carefully.
      • Make sure that you disconnect the battery's wire before you remove the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: adım 3, 2 resimden 1. Graco Secure Coverage LED Parent Unit Replacement, LED Parent Unit: adım 3, 2 resimden 2.
      • There are two screws on the rare case of the device. For the one shown in blue marker requires either an extended screwdriver or putting on a little pressure on a regular screwdriver.
      • Remove the two 9mm Phillips #1 screws from the rare case of the device.
      • If you cannot remove the screw with low pressure, do not use high pressure to remove it. It may cause a damage on the device case. Use an extended screwdriver instead.
      FixBot'a Sor
      Yorum Ekle
    2. Graco Secure Coverage LED Parent Unit Replacement: adım 4, 2 resimden 1. Graco Secure Coverage LED Parent Unit Replacement: adım 4, 2 resimden 2.
      • Using opening plastic tool, pry the two grey cases from both sides of the device.
      • Take your time and apply constant force to avoid breaking or damaging any other plastic parts.
      • While pry off the grey cases, hold the device with your other hand to remove the cases
      FixBot'a Sor
      Yorum Ekle
    3. Graco Secure Coverage LED Parent Unit Replacement: adım 5, 1 resimden 1.
      • Pry the edges of the device to separate the front and rare cases.
      • While prying the edges, hold the device with one hand to pull out each case a part.
      • Make sure you use a constant force, and the pushbuttons are pried off completely.
      FixBot'a Sor
      Yorum Ekle
    4. Graco Secure Coverage LED Parent Unit Replacement: adım 6, 2 resimden 1. Graco Secure Coverage LED Parent Unit Replacement: adım 6, 2 resimden 2.
      • Remove the 7mm Phillips #1 screw from the mother board.
      • Place the screw in a secure place.
      FixBot'a Sor
      Yorum Ekle
    5. Graco Secure Coverage LED Parent Unit Replacement: adım 7, 2 resimden 1. Graco Secure Coverage LED Parent Unit Replacement: adım 7, 2 resimden 2.
      • Flip over the motherboard.
      • Solder off LED from motherboard.
      • There are many pins attached to the motherboard, make sure you solder off the proper pins that attached to the LED's.
      • Replace the LED's
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bryson Wolff
237 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 6-5, Remmell Fall 2015 USF Tampa, Team 6-5, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S6G5
4 Üyeler
56 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 415
