Ana içeriğe geç
GravityLight Dial Replacement
Neye ihtiyacın var
  1. GravityLight Dial Replacement, Removing the Front Panel: adım 1, 2 resimden 1. GravityLight Dial Replacement, Removing the Front Panel: adım 1, 2 resimden 2.
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Dial Replacement, Opening the Device Housing: adım 2, 1 resimden 1.
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Dial Replacement, Isolating the Front Panel: adım 3, 1 resimden 1.
    • Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
    • Ignore the back piece for now, but keep it in a safe place.
  4. GravityLight Dial Replacement, Popping the Dial out: adım 4, 2 resimden 1. GravityLight Dial Replacement, Popping the Dial out: adım 4, 2 resimden 2.
    • Use two hands to push the dial tabs inward, towards the center of the dial.
    • Push the tabs downward and through to the other side of the casing.
    • Flip the front panel over.
  5. GravityLight Dial Replacement, Removing the Dial: adım 5, 1 resimden 1.
    • Fully remove the dial by pulling it out from the front.
Sonuç
Michallynn Hoffman
317 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G2
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 777
