Ana içeriğe geç
GravityLight Internal Gears Replacement
Neye ihtiyacın var
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: adım 1, 2 resimden 1. GravityLight Internal Gears Replacement, Removing the Front Panel: adım 1, 2 resimden 2.
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: adım 2, 1 resimden 1.
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: adım 3, 1 resimden 1.
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: adım 4, 1 resimden 1.
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: adım 5, 1 resimden 1.
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: adım 6, 1 resimden 1.
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: adım 7, 2 resimden 1. GravityLight Internal Gears Replacement, Removing Internal Gears: adım 7, 2 resimden 2.
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
Sonuç
Michallynn Hoffman
317 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Forte Fall 2014 Cal Poly, Team 12-2, Forte Fall 2014 üyesi
CPSU-FORTE-F14S12G2
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Where can we find the replacement gears?
fb - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 3,057
