Ana içeriğe geç
Greist Buttonholer Fork Arm Spring Replacement
Neye ihtiyacın var
  1. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: adım 1, 3 resimden 1. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: adım 1, 3 resimden 2. Greist Buttonholer Fork Arm Spring Replacement, Unscrew the Lower Hook Holding the Spring: adım 1, 3 resimden 3.
    • Unscrew the screw located underneath fork arm using a Flathead screwdriver.
  2. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: adım 2, 3 resimden 1. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: adım 2, 3 resimden 2. Greist Buttonholer Fork Arm Spring Replacement, Remove the Lower Hook: adım 2, 3 resimden 3.
    • Raise the fork arm so that it is parallel with the upper hook.
    • Turn the lower hook towards you from the bottom, and remove.
  3. Greist Buttonholer Fork Arm Spring Replacement, Replace the Spring: adım 3, 2 resimden 1. Greist Buttonholer Fork Arm Spring Replacement, Replace the Spring: adım 3, 2 resimden 2.
    • Remove the old spring from the hook.
    • Add the new spring to the hook.
Sonuç
Michael Sykes
552 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 3-6, Brown Fall 2014 USF Tampa, Team 3-6, Brown Fall 2014 üyesi
USFT-BROWN-F14S3G6
5 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Will the spring look distorted if it needs replacing?
Sarah Turnbull - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 276
